Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Washer takes forever to fill
My 2 year old FisherPaykel washer fills very, very slowly when using cold water. I started by checking the hose at the faucet end to ensure that the screen wasn't clogged. Then, I removed the hose completely; reattached one end to the faucet, turned on the faucet and let cold water run into a pail. I re-attached the hose to the machine, turned the faucet on and the cold water barely drips into the machine. If I change the setting to Warm, the water runs more quickly, but, obviously is running only hot.
  • Sharon Ferguson Jun 04, 2007
    There is no screen at the washer connection. I did try the hose from the faucet to a pail and the cold water runs just fine.
    I've called the repairman as I concur that if it's an inlet valve, let him do it!
You said you checked the screen at the faucet end, did you check the one at the washer connection? Most washing machines have a wire mesh screen which sits inside the plastic connector that the hose connects to. You will have to use a small pointed object (like an ice pick) to remove the screen and clean it. Be careful not to damage it, I have ruined them on more than one occasion and had to replace it with a new one. If that is not the problem, there is likely a problem with the valve that is controlled by the hot/cold knob. I am not familiar with your washer brand, but mine required quite a bit of disassembly to get to the valve and switch, and in my opinion is a job better left to the local repair man.
Posted on Jun 04, 2007
This washer is one year old in a new house. the cold water seems to take forever to fill - is this normal???
WEll, maybe not. Disconnect the hose and test flow there. Items to include in your ivestigation are tap washer on hose faucet, INLET screen on machine hook ups...Often the screens plug up with particulate matter....
Oct 06, 2010 | Frigidaire GLTF2940ES Front Load Washer
Our PAV2300 has a problem filling. When I set it
I can tell you its not in the hoses, typically in the washer where the hoses go in there will be a screen. Check these screens, you will get a lot of sediment built up on these, i have to clean up mine every 2 years. This will still have to be done even if there is a water softener. If this is not the problem then I suggest checking every valve in the cold water system. Making sure they are opening fully.
Jun 24, 2010 | Maytag PAV2300 Top Load Washer
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Water comes out verryy slowly when using cold wash GE large capcity washer
check the fill hose washer located in the washer cold water fill hose,they get clogged with lime and such,and when you replace the washer run hot water thru the hose to clean it out thoroughly,
Apr 24, 2010 | GE Profile WPRE6100G Top Load Washer
Cold water enters washer very slowly
First - check the water inlet hose screen for calcium or rust build-up.
If cold water is filling slowly, take these steps:
  1. Unplug the washer.
  2. Turn off the cold water supply faucet.
  3. Remove the fill hose connected to the back of the washer.
  4. Checkthe fill screen on the cold water inlet valve for debris or depositsthat can restrict the water flow. If necessary, you can carefully pullthe screen out and clean it. Flush the inlet thoroughly and replace thescreen. NOTE: If debris makes it past this screen, it can cause thevalve to leak and cause a flood in your laundry room. Monitor thewasher for this type of problem is you pull the screen out and clean it.
  5. Placethe end of the hose in a bucket and briefly turn on the faucet to checkfor proper pressure and flow from the cold water hose. If waterpressure from the cold inlet water hose is bad, check the hose forclogs. If the hose is okay, then I recommend calling a plumber to checkthe water supply to your washer cold water faucet.
  6. If the above checks do not help you resolve the fill problem, you will likely need to replace the inlet fill valve.
Your cold water fill valve (mixer valve) solenoid has failed if after cleaning - the condition remains.
CLICK HERE for a replacement part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 24, 2009 | Roper RAS8445KQ Top Load Washer
When washer fills with cold water there is very little pressure and it takes forever to fill.
Turn off the cold water valve.
Remove the cold water hose from the washer. Clean out the filter screen on the water valve. Replace the hose and run the washer.
Apr 21, 2009 | Washing Machines
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Apr 18, 2009 | Kenmore 23822 Top Load Washer
Kenmore 110 Top Load Washer-cold water fills extremely slowly
No it is probably the screen that is either in the end of the hose that attaches to the machine, and/or the screen is placed so that the cone is toward the machine instead of pointing away from the machine.
If the cone is pointing towards the machine any debris in the lines would collect and eventually fill the screen cone and slow or shut off water flow.
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Magic Chef washer 15 years old, fills slow no hot water
Pull the hot /cold hoses off and clean out the 2 screens in the valve.Put the hoses back on and re try washer .Problem solved?If still no hot water ,replace your water valve. Please Rate This !!!!
Jun 19, 2008 | Magic Chef CAV2000AWW Top Load Washer
sediment gets clogged in the valve that cant be cleaned if you replaced the water valve it will solve the problem
Nov 25, 2007 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
156 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
shaun taylor
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
