Question about Yamaha Music
Does the old yamaha spx 990 or spx 1000 have the effect delay dis
What other spx units have the effect delay distortion besides the spx 50d and spx 2000?
2 Suggested Answers
  • 5603 Answers
SOURCE: The screen of my SPX-90 yamaha reverb is showing
Check the power supply voltages. Likely the 5 volts is low or out of tolerance. You MAY need to check that it is pure DC as bad filter caps can cause it to ripple out of operating range BUT still show OK on a meter.
Posted on Nov 26, 2009
Can't find a manual but can still explain. Delays, chorus, flangers, and reverbs are all the same effect except the different names of them will allow you different adjustments. Chorus usually has a width control which controls pitch shifting. Flangers and delays will have a feedback control which simply means, how many times you hear the echo. On reverb units, room size means how long of echo(even though it;s short) you want. Delay is the same with much longer echo, feedback is the same as on flangers except the flangers time is very short meaning the effect is at almost the exact time resulting in feedback causing a metalic sound. I probaly just confused you but good digital delays usually have all the features and will usually do all 4 effects depending on how you set them. If you want delay, set width on 0 and adjust time and feedback. For flanging, adjust width and speed and feedback. Chorusing, adjust time, width, and speed. Reverb, adjust time, set width on 0, and feedback. I see it has a level(mixture, how much effect you hear), and a replay(feedback, how many times you hear it), and a delay knob,(how long the echo will be) The range/mode switch allows for settings of diferent time lengths and INF setting allows for infinite repeat. Hope this helps.
Mar 09, 2013 | Applause MAE148 AcoEle Mandolin Natural...
Line 6 how do i get it to work
Line 6 connected to AC power and LED showing power to unit. Guitar into effect input, effect output to guitar amp. Does guitar make sound through amp in bypass mode? No then check cables...yes then use foot switch to turn Line 6 effects unit on. Adjust control knobs for desired effect levels/settings.
If pedal provides no switch defective or internal electronics in need of repair.
Oct 26, 2012 | Line 6 DL4 Delay Modeler Effects Guitar
I have a problem with my roland jw50 keyboard,,, i dont really know the cause ,,, any key i press makes only a single tone and it is distorted.. thank you..
Check the setting for your envelope ,attack, decay, and release
Check Effects settngs reverb/delay chorus/flanger
you probably have one or a couple of these setting way off
May 16, 2011 | Music
How To Use The effect Loop?
The effect loop is to use exteernal effect module... It is NOT to use guitar pedals !!!! The signals are line levels, NOT guitar type levels. An example of a device might be an Alesis Quadraverb. You take the effect send jack and run it into the inout of the effects module and the output of the effects module into the effects return jack. Many try to use guitar pedals and massive distortion results because levels are too high for the pedals.
May 12, 2011 | Peavey 6505+ 112 Combo Amp Combo
I just bought 2 of the DSR 115 Yamaha speakers. One of them is NOW making a "light fluttering" sound from the woofer! Could this damage caused by my "Yamaha GQ 1031 b EQ"...
Don't mess with it and risk voiding your warranty. These are a servoed speaker and there is a problem with the feedback in it. Exercise your warranty immediately.
May 04, 2011 | Yamaha DSR115 Powered PA Speaker (1300...
Basically i cannot seem to make the pedal work in tandem with my crate flexwave 120w 2x12 dsp amp i prefer to use the built in dis,chorus, and delay effects but can find no way to put the hb01 behind the...
Norrmally you run the guitar into the pedal and then into the amp. IF you want it behind the built in effects, The look on page 6 of your users manual showing the special cable you will need to do the "insert" of your effects pedal.
If you don't have a manual, download it here:
Jan 11, 2011 | Behringer HB01 Hellbabe Wah Pedal
Increase in delay effect during a lead setting.
This may be he characteristic of mixing of the delayed when high distortion is present...
I would go to music store and compare... I tend to think this is the nature of the beast.
If you consider what the waveforms look like with distortion and then add them delayed... they limit out and when added there is a significant difference when adding or mixing waves that are delayed when squared compared to nice sine waves.
May 08, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
The screen of my SPX-90 yamaha reverb is showing weird symbols and the unit does not operate anymore. Any idee od the problem? Thank-you
Nov 26, 2009 | Yamaha Music
How to set up foot switch in order
Personally I recommend the following set up:
This will ensure that the signal won't have any odd hiccups due to an odd pedal setup. But if you play around with different orders, you can end up with some very interested sounds.
Nov 24, 2009 | Boss Mt 2 Metal Zone Effects Pedal
The correct order for Effects pedals.
Personally, I like to have all "tone effects", such as wahs, distortions and equalizers in front of "time effects" such as phasers, chorus, flangers and delays. See my set up in the photo. Guitar input is from right to left, starting with the wah pedal.
Tom, 30yr player
May 15, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Music Logo
200 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Are you a Yamaha Music Expert? Answer questions, earn points and help others
