Question about Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook
Lcd is not working
I drop my PowerBook G4 and when i turn on the my Powerbook the screen was not working. everything was fine except the screen i can see a shadow of a picture and words at the screen but the thing is there is no light. can you please give some tip on how to fix this thanks
  • 502 Answers
This could be a backlight issue, an inverter issue or a logic board issue. Given that you dropped it, the backlight issue is the most likely because the ccfl bulbs inside the screen are breakable. Backlight repairs are somewhat difficult. As much as I would like to be able to tell you a quickfix that will solve backlight the problem, it's a pretty arduous repair that requires 1-2 hours for a trained person. It's feasible to do it yourself if you're tech savy, but you'll most likely have to google for guides that show you exactly how to replace the backlight step by step. Check on ifixit on how to take the screen apart and make sure inverter is still connected properly. If so, you have a backlight issue. I work for Mac Repair NYC and i have to fix this problem a lot, it's so easy to break the lightbulb in the process.
Posted on May 27, 2009
  • 178 Answers
Yes I agree known problem with this model when dropped cathrode cable discconects from the device on one end. Allowing you to see some kind of image on the screen. i can fix it fo you. If you like check my website.
Posted on Feb 10, 2008
  • 4 Answers
You've either broken the Cold cathode (a strip light that runs along the bottom of the LCD to provide a backlight)or damaged the inverter board (a chip that boosts the 24.5V of the laptop's battery to the 400V that the light needs to work) unless you fancy ruining your warranty and getting your hands dirty with replacing the board ($40-$90) or the LCD ($400-$600) i'd do as the guy says and have a certified tech have a look at it. of course, there's no fun in that, but you're more likely to get a working machine at the end of the day...
Posted on Jul 28, 2007
I'd highly recommend taking into the Apple Genius bar. You've definitely damaged something. You might be lucky and one of the connectors came loose, but most likely you damaged the LCD which will need to be replaced.
Posted on Jun 29, 2007
Everytime I login to my Mac PowerBook G4 the screen shows logging in and then after about 30 seconds it goes back to login screen
HELLO
FOR SOLVE THIS ..Starting your Mac in safe mode does the following: ... Start or restart your Mac, thenimmediately press and hold the Shift ... If your startup disk is encrypted with FileVault, you might be asked to log in twice: once to unlock the startup disk, ... If the issue comes back, you might have incompatible login items. 1 800 726 0294 Apple Support Number Mac Technical Support Help Apple Customer Support Number 1 800 726 0294 Mac Help USA https://plus.google.com/u/1/116937682228750782866 APPLE SUPPORT NUMBER
Sep 09, 2017 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Can I buy any webcam for my apple powerbook g4?
Yes you can buy a webcam for your Powerbook G4. Any standard USB webcam should work fine with your PowerBook.
Feb 17, 2011 | Apple PowerBook G4 Mac Notebook
Powerbook g4 Aluminum 15 LCD
it could be the inverter to the display, or the graphics chipset or the connection between them.
Nov 02, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
How to replace the lcd on a powerbook g4 model m8407
Here is a service guide for the Powerbook G4. It has the step by step instructions.
http://www.powerbookmedic.com/xcart1/files/G4alum12.pdf
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 10, 2008 | Apple PowerBook G4 Mac Notebook
Powerbook G4 LCD White
Well you either have one of 3 things wrong with the computer:
  1. the video connector on the logic board is broken or not making a full connection
  2. the video cable from the logic board to the LCD panel is damaged.
  3. the LCD panel is dead
Oct 15, 2008 | Apple PowerBook G4 Mac Notebook
Apple Powerbook G4 1.67 GHz LCD problem
Probably more like a Video cabling issue or a Screen assy getting bad connections.. Both have been seen here.
Jul 16, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
PowerBook g4 15" Screen Won't Display Anything!
your lcd probably just went out or the connecting cable just came loose(its in behind the lcd under the apple logo that lights up when you turn it on) if you open and close it frequently it will cause this
May 26, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Powerbook G4 (1 GHz), 15" LCD glitchy
It could well be the ribbon cable between the screen and motherboard is knackered. Depends how brave you are at dismanteling computers, if you search on powerbook parts you may be able to find a company that scraps computers who could sell you the cable if it is a separate item otherwise it will be an expensive Apple repair!
Kevan
Nov 18, 2007 | Apple PowerBook G4 Mac Notebook
Apple 15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook Logo
274 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Peter Dragonetti
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
