Question about Fujitsu fi-5530C Scanner
E3 error on fujitsu fi-5530C
After dismantling, cleaning, and reassembling. Same error still present. Please help
    Problem Solver:
  • 16 Answers
You have a rear optical error.
check the lamp is lighting.... open the ADF and push in the cover open switch. if one if off, replace it or the lamp inverter
swap the cameras over to be sure the fault follows to an E2
replace the optical unit
good luck
Posted on Sep 17, 2009
Backside Optical alarm (G) when using Duplex option
Hi Rasha,
ADF backside scanning optical alarm (upper optical unit ADF) is E3 alarm. When there is an irregularity in the amount of light (ADF back), "E" and "3" will be displayed alternately on the function number display panel of the scanner.
Please check the followings:
1.Does the same symptom occur after turning OFF and ON the scanner?
2. Is the lower glass (white sheet guide) of the reading section dirty? Open the ADF, and clean the sheet guide (white part) and the glass.
3. Is the upper Optical unit ADF dirty? Are the cables damaged? Are the connectors connected properly?
4.E3: Is the upper lamp ON? Are the cables damaged? Are the connectors connected properly? Disconnect the SCSI cable and turn the scanner ON. Open the ADF and press ADF cover open sensor as shown below to see if the ADF lamps light which has to be replaced.
I would recommend to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jun 12, 2013 | Fujitsu fi-4750C Flatbed Scanner
The scanner wont scan.. it says the scanner is out of paper
Remove your scanner from the PC and uninstall the software. Now reinstall the software and connect the scanner to be detected and installed. Check scanner properties to see the settings.
If the fault stays get intouch with Fujitsu dealer.
Sep 28, 2010 | Fujitsu fi-5530C Scanner
Scanned instance of document is blurry and background 'flecked'
Since I have no idea where you are located, the best I can do is provide you with a link to Fujitsu' service centre.
We service the following brands of scanners
Nov 03, 2017 | Fujitsu fi-5530C Scanner
Getting Error SA010771 for Fujitsu scanner when I press the Scan button
Found it! To fix the SA010771 error.
This assumes you have already sat there (like I did) and tried everything including adding the event in the scanner settings and changing 0 to ScandALL PRO)
Open Scandall Pro click SCAN - Batch Scan Settings - Add a new profile, for the moment just leave everything as is (change it later). Click Close then close ScandALL PRO and then reopen it.
Click TOOL - Preferences - Event tab, you should now be able to select Profile 1 (or whatever you named it) from the dropdown for Scan.
You can figure the rest out from there : )
Jimi@JamesGoethe.com
Nov 16, 2009 | Fujitsu fi-5530C Scanner
Scandall 21 Automatically Saves Scan As Temp Fil
go into the settings on your computer and change the setting to save all scans
Jul 20, 2009 | Fujitsu fi-5530C Scanner
Fi-4120c2 error Code
The scanner does self-diagnostic when receiving Read Command (to start scanning) and displays the result if any error or alarm is detected.
Error code-E3 in Fi-4120c2 scanner means "Light intensity check" . When this error is displayed on the scanner panel, TWAIN displays the following error-
" Irregular status is detected in scanner. If this status recurs after power cycling, please give following Sense key and ASC code to your service provider.
If ASC code is the following, please confirm following status before power cycling’
- When ASC=0x580, confirm if the shipping lock (if any) is set at “Release” position.
- When ASC=0x680, clean the sheet guide (white part) in ADF.
(Error Code DS42001)
E3 explains Optical alarm (back). This alarm occurs if the gain adjustment of the CCD amplifier does not succeed at a READ command for the first document, or during scanning.
Probable causes:
- The lamp, the optical system or white sheet guide is dirty.
- Defective lamp or CCD.
- Connector disconnected
To check and resolve the issue, lease follow the steps provided below:
1. Is sheet guide (white part) in the reading position dirty?
#Open the ADF and clean the sheet guide (white part) and the glass.
2. Is the lamp ON?
3. Are the cables damaged?
4. Are the connectors connected correctly?
#Disconnect SCSI cable and turn the scanner ON. Open the ADF and press Cover open sensor to see if the lamp lights. If not, the error is caused by the defective lamp.
5. Is the optical unit dirty?
6. Are the cables damaged?
7. Are the connectors connected correctly?
# Check and Clean (ADF back):
# Check if inside of the grass for Upper unit ASSY is dirty. Clean inside of the glass of the dust cover.
9. If the issue still persists, then you may have to replace Optical unit.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Oct 08, 2008 | Fujitsu fi-4120C Path-Through Scanner
Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
May 29, 2008 | Fujitsu fi-5120C
Multiple sheets
You can try to clean the retard pad under the feed roll, but for best results you should replace it. Parts are readily available on the web. You should spend around $20 for the pad, and $50 for the feed roll. You may not need the roll. Examine it and see how the tread looks. These parts are easy to replace.
Feb 29, 2008 | Fujitsu fi-5530C Scanner
Error e3
Drain pump probably not working. Put machine on cycle 7 and it should turn on the drain pump straight away. you can hear this near the bottom of the machine. if it is silent hten the pump probably needs replacing. I repaired mine be removing it and then dismantle the magnet from the tube then give it a good clean out.
Feb 03, 2008 | Hoover 24 in. HD97E Free-standing...
Fujitsu fi-5530C Scanner Logo
1,390 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
