Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm and EF 75-300mm Lenses
Most of picture blanked out or blocked out
I have a Canon 300d. Suddenly 2/3's of the picture appears blacked out. I tried downloading the pictures I took to see if it was an LCD issue and the pictures are the same as what is shown in the LCD scree. The Battery is Full. Changed lens - Nothing was different. Nothing physically blocking. Help...
  • 4 more comments
  • Ted Brancheau Jun 04, 2007
    The camera is an EOS 300D. I took off the lens and yes the mirror did come all the way up. Any more idea's? I did try reformatting the card. No change. Thanks
  • star8278 Aug 06, 2008
    I am also having this same problem with my Canon. Was shooting fine in auto with flash when it started happening. Has there ever been a solution found to this problem.
  • bwessels Oct 06, 2008
    same problem 2/3 photo blacked out.
  • debch Dec 13, 2008
    I have the same problem. The pins on the card recepticle and the contacts in the CF card look fine.
  • hartopus Jan 10, 2009
    im experience the same problem too, the camera doing fine and suddenly in my review lcd the picture wont shown and when i tried again the lcd turn to blank .. is it because the broken plastic actuating rod.could someone advise me..
  • Anonymous Apr 16, 2009
    2/3 of picture is black
  • 42 Answers
Does this problem occurs at all shutter speeds or high speeds such as 1/200 or above?
Posted on Aug 26, 2007
    Genius:
  • 2,985 Answers
This seems to be a oricessing orblem and the process is failing to complete or corrupting. Rreformat the card in the camera Try another card.
Posted on Jun 04, 2007
  • john ash
    john ash Jun 04, 2007
    Another thought
    Is this model a SLT- with a mirror 0r and LCD view finder?
    Take the lens off and press the shutter to see if the mirror comes all the way up.
Eos 300d when used in AV mode pictures come out black
Sounds like a problem with the aperture unit in the lens
Jun 08, 2012 | Canon Digital Rebel / EOS-300D Digital...
Canon EOS 300D which is over Exposing
try adjusting the exposure levels set default zero to negatives untill your sure of the right exposure that you want....hope this helps
Nov 25, 2009 | Canon Digital Rebel / EOS-300D Digital...
My EOS 300d is not recognized by computer
have you tried to change the USB cable, or USB plug?
if did not work, try uninstalling the drivers & reinstaling them again (also update the firmware of you camera)
hope this will work
Aug 21, 2009 | Canon Digital Rebel / EOS-300D Digital...
My EOS 300d blank images
That problem is normally associated with having a too high shutter speed when using flash. If it happens in any mode, with or without flash you may have a shutter blind issue.
Test the camera at various shutter speeds and compare the results. If this black area is consistant across different shutter speeds, send it in for repair. It is most likely the shutter curtain not making a pass across the sensor fast enough, still obscuring the sensor when a photo was taken.
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Missing light on pictures
Hi Louise. I found you anyway!
Troubleshooting this could get complicated, so I want to try some basic stuff first and get that out of the way.
First: Let's check your camera settings, You may have accidentally set the exposure setting incorrectly. Have you tried resetting your camera back to factory default? The way to do it is in Setup Menu number 2. Scroll down to "Clear All Camera Settings". Then press the Set button. This will take your camera back to like it was when you took it out of the box.
Now try taking a picture, If you still have the same problem, let me know by commenting in this session and we'll move on to step #2.
Rob
Mar 01, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon 300d gives error 99 and does not work
Try the following diagnosis steps: -
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Nov 28, 2008 | Canon Digital Rebel / EOS-300D Digital...
I have Canon EOS 300D digital Rebel. I have had intermittent problem with the camera display screen going blank even though I put a freshly charged battery in. Usually I can take a couple pictures then the...
Strange, intermittent problems with the EOS Digital Rebels can be caused by a defective shutter release switch. We charge about $85 to replace it.
Nov 12, 2008 | Canon Cameras
Canon Digital IXUS 70, Camera Blank
This really sounds like a potential CCD failure. To confirm, take a picture while the screen is black, then download to your computer to see if the picture is also black.
If so, it is difficult for the average person to replace a CCD, and should only be done by an authorized Canon repair rep. If still under warranty, Canon will fix this for you for free. If not, recommend calling Canon anyways and complaining (this should not happen in such a recent model camera). If you complain, and possibly ask to speak to a supervisor, you just might get lucky.
Here's the number:
1-800-OK-CANON
May 17, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm and EF 75-300mm Lenses Logo
168 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
