Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
JENN-AIR SCE30600 COOLING FAN & OVEN LIGHT STAYS ON
CLOCK LIGHT WENT OUT #1 ON KEY PAD NOT WORKING. I REPLACED CLOCK ASSEMBLY OK NOW BUT #1 STILL DON'T WORK AND COOLING FAN AN LIGHT STAYS ON ANY HELP WOULD BE APPRECIATED
  • 25 Answers
Small circuit board in back for fan & LIGHT BAD.
Posted on Feb 12, 2009
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
Jenn-air sce30600 just replaced membrane offswitch
sounds like more than switch issue probably main circuit board!!!! :) have you tried jenn aire support?
Jul 07, 2009 | Ovens
Jenn-Air Wall Oven up controls don't work
you have a touch pad issue, whats the model and serial ill look up the part for you, sometimes you can just get the key pad, sometimes comes sa a whole console or as part of the electronic control itself.
Mar 17, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Oven fan won't switch off
it sounds like the clock on the oven has been adjusted, if the clock has been adjust the fan will continue to "Cool Down" the oven for the period set on the clock, it is also a possibility tht the clock is faulty, is the clock digital or Analouge
Jan 30, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Jennair range
f-5 means the clock/oven control is bad. the only way to fix this is to replace the oven control
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Problems with Jenn-Air Electric Double-Wall Oven
that board supplies power to the light unit and it is very easy to replace if that is what is wrong. it can also be the led display unit also. cost about $150 each i think.
Oct 26, 2007 | Jenn-Air WW30430P Stainless Steel Electric...
Beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Sep 05, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
416 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
