Question about Panasonic KX-T7630 Corded Phone
Extension Lights Don't Light Up
I have programmed all the extensions I want on the phone but the lights don't seem to light up when they are using their phone.
  • Panasonic Master
  • 2,460 Answers
When you programmed them, did you press PROG the button 1 plus the ext, or did you use 2? The digit 1 makes it a DSS button, 2 a speed dial.
Carl
Posted on Jan 10, 2009
Light indicating an extension is in use not lit up
The light is either not programmed, or the extension is disconnected.
In the first case, press PROG the button and dial 1 plus the extension number and ENTER. In the second case, the digital phone has to be in place and idle before the light will go out.
Apr 22, 2014 | Panasonic KXDT343 Phone
Panasonic kx dt 333 When the phone rings the red light doesn't flash to denote which line it's coming in on. Any idea how to resolve this?
Which means what? You have a solid red light on the line or you don't have the line at all. A TDA system rings by a process called ICD groups. You can have a phone in an ICD (600 by default) and tell it the number of rings to delay, not ring, or immediate ring, but that means that the line button will flash as the call is coming in. If you don't assign it to a group, it's really stupid and won't do anything but light solid red.
If you have access to installer programming, you assign the extension to the main ICD. If you don't you have to call your Panasonic installer or dealer.
Carl
May 11, 2011 | Panasonic KXDT333 Phone
Some extension lights do not light up on my phone. How can I fix this?
Press PROGRAM and the button where you have programmed the extensions. What does it say? If it doesn't have EXT in front of it, dial 1 and the extension and STORE or ENTER. The button could be just programmed without the leading "1" and it will dial an extension but not monitor its status.
Carl
Mar 03, 2011 | Panasonic KX-T7630 Corded Phone
OK, I'm nearly there. I've worked out how to label the extension, how to re-do the extension numbers on the phones and change their position. The only problem I have is when I re-do the extension the light...
You're using the buttons on the left side of the phone? What does it read when you press PROGRAM and the programmed button? A TA series does not have "on hook" dialing, you have to press the SP PHONE button or pick up the handset. If the button is programmed properly, the display will read EXT-xxx when you press PROGRAM and the corresponding button on the left side. It will also follow the on-hook/off-hook status of the extension.
Carl
Feb 07, 2011 | Panasonic KX-T7730 Corded Phone
Programming extensions in the phone
If you have manual(z), they should. One, the OM (operating manual) will tell you how to set up your personal programming.
The buttons on the left side of a 7730 have lights, the buttons on the right do not, so they are programmed differently. Left side is DSS, right side is PF (personal feature). If you have spare left side buttons, press PROGRAM the button and dial 1 plus the ext number and STORE. The light will now follow the activity of the extension you programmed.
The buttons on the right have no lights, so you can only put in extension speed dial numbers. For that, press PROGRAM, the button, and dial the 3 digit extension number and STORE.
Depending on the system your phone is connected with, you can just press the button to dial, or you have to pick up the handset or SP-PHONE and select intercom (if not selected) and it will dial that extension, or if the system is a TAW, TD or higher, just press the button.
Carl
Dec 03, 2009 | Panasonic KX-T7730 Corded Phone
How do I set phone to ring at my extention?
Partner, all releases.
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist’s extension to Immediate Ring and the lines at the users’ extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users’ extensions -with the receptionist providing backup -set the line at the users’ extensions to Immediate Ring. Then set the line (or lines) at the receptionist’s extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist’s extension.
Programming
To change the way outside lines or pools ring at an extension:
  1. Press [ Feature ] [ 0 ] [ 0 ] [ System Program ] [ System Program ] [ Central Tel Program ].
  2. Enter the number of the extension to be programmed for Line Ringing. The green lights next to the line or pool buttons on the phone show the current Line Ringing settings for all lines assigned to the extension. (If a line is not assigned to a button, the green light next to the button is off.) The following ringing options can be shown by the green light next to the line button.
    • Immediate Ring - on steady
    • Delayed Ring - flashes slowly
    • No Ring - flutters quickly
  3. To change Line Ringing for any line, press the line or pool button until the button light shows the correct setting (the setting for the currently selected line or pool also appears on the display).
  4. Continue programming or exit programming mode.
Dec 01, 2009 | AT&T Lucent MLS-12D Phone
Need an installation and setup guide for tmc soho m4810.
you have to assign an ext to the phone.Press Program and extension button to assign it to an extension.
all phones have to have different assigned ext (obviously)...
To cancel stored extension(to change) Press program, press PAGE twice, press mute.
I need the users guide!!! have quite a few install and set up guides - I just need the users guide!!! need to change time and other things!!!
Please help...will trade...
Jun 30, 2009 | TMC M4810 NON-KSU Corded Telephone
Stop ringing at certian phones when outside calls come in.
http://dstech1.com/programming-line-ringing/
Examples
Receptionist Call Routing. If you want calls to be answered by the receptionist first, set the lines at the receptionist's extension to Immediate Ring and the lines at the users' extensions to No Ring. (This is the factory setting)
Receptionist Backup. If you want all calls on a line to ring directly at users' extensions -with the receptionist providing backup -set the line at the users' extensions to Immediate Ring. Then set the line (or lines) at the receptionist's extension to Delayed Ring. An incoming call that is not answered by a user within 20 seconds will also ring at the receptionist's extension.
Programming
Jan 09, 2009 | Lucent PARTNER18 Corded Phone
Extension indicator lights not working
Walk up to the phone, press FEAT 00 press the button you want to program then press INTERCOM and dial the 2 digit extension or * + 2 digit if you want Voice signalling. Do this for all the buttons you want to program and end with FEAT 00.
Carl
Nov 14, 2008 | Avaya Corded Phone avaparp18d
KX-T7453 co light will not light when someone is on the phone
I don't know what instructions you have, but try these.
Press PROGRAM 99 and the button you want to program
Dial 1 plus the extension number and STORE.
Was that what you were doing?
Carl
Aug 21, 2008 | Panasonic KX-T7453 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
83 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
