GE WASHER WJRR4170G0WW-SPIN Cycle does not work- just make sound.
I almost 2 year old GE WASHER WJRR4170G0WW - TOP LOAD.
In Drain/Spin Cycle, the Drain Cyle works fine but after drain it's doesn't spin, just makes noise.
A response will be much apprecoated.
  • Anonymous Mar 17, 2014
    does not spin in the spin cyles ge brand only a week old
My washer is 2 years old and this is 1/2 the cost I paid for it new. My review of this product after 35 years of technical experience; GE products (Hotpoint)aren't worth buying any longer.
The problem is the Motor. There is an electronic PC Board attached to the top of the motor and under the drip protector, which protects the PC Board. On this board, there is a green flashing light which displays trouble codes by flashing. Unplug the washer, remove the 3 screws from behind the control panel. Slowly pull the control panel toward you and slide it to the right to release. Inside the washer, there is a diagram with the trouble codes printed in the lower right hand corner. Everything else is self explained. Flashes indicate the problem and the solution is all written. Since I have the same problem and a technician, this is a defective product GE has discontinued and re-manufactured. After phoning GE the motor # Normal 0 WH20X10051 cost $252.25 to ship to my location.
Posted on Jun 18, 2009
  • Washing Mach... Master
  • 8,220 Answers
It could be anything from a bad belt to a bad clutch to a bad tranny. In my opinion this washer is not worth repairing.
Posted on Jan 09, 2009
Water in clothes after spin cycle
need to open washer and check the DRAIN MOTOR PUMP , usually gets clogged with lint and debris , usually located at the bottom side , small motor w/ propeller ,where the drain hose is connected, AJ
Nov 11, 2009 | GE WJRR4170E Top Load Washer
Won't advance to spin cycle from drain cycle
install new timer....thumbs up...
VE6GAR 73 88 99
Aug 10, 2009 | Washing Machines
GE Top Loader 10 years old. won't drain
Timer is faulty and should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | GE WBSR3140DW Top Load Washer
Washer wil not spin or drain out after cycle completed
sounds like drain is plugged. this is a fairly easy fix,and you actually get paid to do it. unscrew the bottom panel of your washer should be 3 screws on the very bottom then you will see a white plug that is about 2 1/2" unscrew it (make sure you have a bowl under it water will leak ) and pull it out. this is where you get paid you will find all kinds of change and junk just clean it out reinstall and your clothes will be a lot drier after the spin cycle
Mar 21, 2009 | GE Energy Star WCVH6260F Front Load Washer
Roper washer will fill but does not spin/drain
Sounds like a lid switch. If it fills and just sits there, Im working on a tutorial for this. Dave www.washermd.com
Jan 13, 2009 | GE WSM2420T Top Load Stacked Washer /...
GE WDSR2080D5WW Top Load Washer
sounds like the agitator is bad not hard to replace look up on internet agitator replacement for that model
Sep 10, 2008 | GE WDSR2080D Top Load Washer
Washer won't drain or spin
Probably a bad drain valve. As long as the tub is still full of water, the controls will not allow it spin, refill, etc. Have a service technician check the drain valve.
Jul 10, 2008 | GE Spacemaker WSLP1100D Top Load Washer
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Apr 01, 2008 | GE WBB4500EWW Top Load Washer
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
1,459 people viewed this question
Top Washing Machines Experts
