Question about Whirlpool LER5636P Electric Dryer
Dryer shuts off early
While drying, it shuts off in 5(?) minutes
  • Whirlpool Master
  • 8,220 Answers
The motor is probably stiff. Reach in and turn the drum by hand. It should be very easy to turn.The motor can be oiled but you will have to make some oil ports. I use an 1/8th inch drill bit and I fill the wells with turbine oil.dryer shuts off early - 47e3cae.jpg
Posted on Jan 09, 2009
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
Bosch WTL5200 silver edition not getting hot enough to dry clothes
Check ur venting inside and outside the machine. the lint basket? is the air blowing out the back without any restrictions? then check ur thermostats with a multi meter for continuity, may also want to check ur moister sensor, if its mis reading the dryness it will shut off heat early
Jul 16, 2012 | Bosch Dryers
I have an LG DLE0442W and its having some problems. Well first to turn it on you have to hold down the power button or the lights will just flicker and it went turn on. When you hold it down it turns on no...
I suspect two issues
1. Need new power button. Easy fix. Check out repairclinic.com or appliancepartspros.com for how to videos and parts.
2. Your sensor strips in dry my have either lint under them or dryer sheet residue on them throwing off the moisture sensor reading and shutting down dryer early.
May 07, 2017 | LG Dryers
Dryer shot off
Try cleaning off the moisture sensor bars. (two 1/4 inch wide, about 5 inch long metal strips about an inch apart inside the dryer, near the lint trap.) These strips can get coated, often times from waxy residue from fabric softener sheets, and then no moisture is detected, so the dryer thinks clothes are dry, and after a short (5 minutes) cool down, it shuts off. If you use the manual / time dry, dryer should work fine even if the sensors are coated.
Apr 16, 2010 | LG DLE2514 Electric Dryer
TheModel 96272100 dryer takes 80 minutes to dry a
the sensor for the heat control needs to be replaced for its shutting down the heat too early making your drying time more longer
Jan 25, 2010 | Dryers
Dryer shuts off after about 5-10 minutes of running. The top of the dryer is hot.
Howdy: There is a thermostat inside the unit in the back. If this has lint clinging to it, it will shut off unit. Also the firing ignitor has two soleniods
that stick and turns off unit too early. But with the top of dryer hot I would say the heat always stays on and the thermostat shuts off ignitor. The firing should be a pulse type heat, not a constant heat. Good luck - Doug
Dec 08, 2009 | Kenmore Dryers
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Shutting off every 20 minutes
Your thremal fuse is getting hot. OR There are overloads attached to the element housing and one of them is getting hot and automatically resetting itself once it is cooled.
Apr 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Auto feature
Faulty selector switch or control card. There is the possibility of a faulty moisture sensor. Can you operate the machine in manual mode ?
Jan 26, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
391 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
