Envision 19" Widescreen Flat-Panel TFT-LCD Monitor
Problem for Envision 19" Widescreen Flat-Panel TFT-LCD Monitor
My screen has "out of range" written across the screen.
By kschwarz on Jan 09, 2009
I moved my screen, and plugged it back in. Now it has out of range written across the middle.
Same Problem
Mar 30, 2009
-   OUT OF RANGE in center of screen.
I set pixel size at 1024 by 768 and screen looks OK.
The OUT OF RANGE thingie is still there.
"The mouse pointer go's right under it",
Like it's something taped on outside of screen.
I've turned the computer & monitor off.
When you start it back up the OUT OF RANGE is still in the
center of the monitor.
HOW do you get the "OUT OF RANGE off of the moniter ? ? ?
-   jkhines
Solution #1
posted on May 22, 2009
Not Rated)
stoneheaded
Rank: Guru
Rating: 90%, 627 votes
Find a blank space on your desktop left, it will bring up a box saying display properties. Go to the properties section and right click on it. Go to the setting section and set the picture resolution to the setting recommended for your monitor in your owners manual. Go down the screen and find the advanced button and right click on it and go to the monitor selection and right click on it. Go to the screen refresh rate and set the recommended refresh rate listed in your owners manual.Click ok and on the settings screen click apply. Then click ok to close the function. This should set the settings for proper use with your computer. If you are using a graphics card you should adjust the same setting levels on it to match up with the monitor. If you have tried all these settings and still cannot get the adjustment to work with your set-up, you can call Envision customer support at this telephone number : 1-888-838-6388. They should be able to help you with your problem. I hope this information helps you with your problem.
Comments:
May 22, 2009
- In the beginning it should say Find a blank space on your desktop and left click on it to bring up the Display properties box.
Was this helpful?
Yes
No
Solution #2
posted on Jan 09, 2009
Not Rated)
mike1989
Rank: Wiz
Rating: 78%, 19 votes
if you have another monitor available .. try using it to reset you refresh rate for the graphics card.. this is usually because certain monitors only accept certain frequencies
Was this helpful?
Yes
No
Popular Solutions for Envision 19" Widescreen
Questions and Unsolved Problems for Envision 19" Widescreen
Do you recommend Envision 19" Widescreen Flat-Panel TFT-LCD Monitor?
Answer
Answer
First my monitors was turning off every few seconds, and was only turning back on when i unplugged... (More)
Answer
I have a MAG 700p, it comes on fine then goes black.....after a minute or so....help!
Answer
have a soyo monito dylm2c86 and it isn't working properly with windows 7
Answer
attempting to connect2026w monitor to a Toshiba laptop as a second monitor, It's now showing lots of... (More)
Describe your Monitors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
in Newport, KY
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
