Question about HP LaserJet 1020 Printer
Alignment amiss and excess ink
It seems that the alignment of my printer is slightly off. When I'm printing anything with graphics (ie. letterhead, business cards, etc.), the graphics on the left side angle up. I'm wondering how I can realign the printing, if I can at all.
Also, with said graphics, there tends to be a line of ink also printed along the left edge of the paper. Is there anyway to eliminate that problem?
    Sniper:
  • 62 Answers
  1. Make sure that the printer is idle and the Ready light is on.
  2. Load the media in the input tray.
  3. Print a cleaning page. Access the printer properties (or printing preferences in Windows 2000 and XP).
NOTE: The cleaning process takes approximately 3 minutes. The cleaning page will stop periodically during the cleaning process. Do not turn the printer off until the cleaning process has finished. You might need to repeat the cleaning process several times to thoroughly clean the printer.
If this doesn't help, let me know and I will further investigate.
Posted on Jan 09, 2009
E02820 Adj. Failed - Irregular alignment pattern
YOU MUST BE USING REFILLED CARTRIDGES. AFTER A COUPLE OF REFILLS THE TECHNOLOGY USED BY EPSON IS "BUBBLE JET" TYPE WHERE THE INK IS EJECTED/SPRAYED ON THE PAPER. after CONTINUAL RE-FILLS THE NOZZLE OF THE PRINT HEAD WIDENS, THUS GIVING YOU SMUDGY/SPRAYED TYPE OF PRINTOUTSW
Dec 10, 2013 | Canon Office Equipment & Supplies
I changed the ink cartrige,it keeps saying alignment cancelled and the copy button keeps flashing - when i open it up the ink cartrige wont slide back out it seems stuck.
The printer needs to be aligned and it wasn't done after changing the catridge so it does not want to continue. Have you tried pushing the flashing copy button to print another alignment page? Do you know how to align the printer?
After changing a cartridge the printer wants to print an alignment page to make sure that it prints correctly. Some printers have you print a page and they auto align themselves. Others cue you to print the alignment page which has a picture or other graphics that are in specific places and then it instructs you to insert the alignment page face down and press "ok". The printer scans the alignment page and configures the print heads to set up by the marks. It uses the alignment page as a map of where the print should be on the paper.
Try unplugging the printer from the power supply and wait about 30 seconds. Then plug it back in and turn it on. The display should say "print alignment page". Choose yes or confirm to continue. Your printer will either print the page and align itself, or print the page and tell you to insert it and continue. Either way follow the prompts and complete the alignment process in order to continue printing as normal.
If you are unable to get the printer to reset and start the alignment procedure over again, please advise and I will help you solve this problem.
Nov 06, 2010 | HP PSC 2210 All-In-One InkJet Printer
When start the printer it print 3 times the head printer alignment before do anything
There are mainly 2 reasons why this happens.
1. If the cartridges or one of the cartridge is running low on ink
2. Once the alignment sheet is printed and if it is wrongly placed for alignment or wrong alignment selected.
Disconnect the power cord from back of printer, wait for 10 seconds and connect it back.
Hope this is helpful
Oct 29, 2010 | HP DesignJet 110 Plus NR InkJet Printer
When I change an ink cartridge, automatically the printer run by itself printing a test page which has to be placed on the scan screen; the problem is the printer runs this process each time it is turned...
The alignment page will continue to print until the alignment is complete. Put the page on the scanner face down on the glass. (Make sure the alignment page printed on plain bright white paper (A4 or letter). Also correctly orient the page on the glass - the section with black squares should be to the left.) Press the scan button and wait until the power button stops blinking.
If the alignment page continues to print, remove the ink cartridges and inspect them. You want to look for any debris (including part of the tape that kept the ink from drying out). Replace the cartridges and check if the problem has been resolved. Do the complete alignment again.
If it persists, clean the electrical contacts with clean water (distilled or bottled) and cotton swabs or lint free material (coffee filters will work). Remove the cartridges and then unplug the printer. Dampen the swab (or alternate material), squeeze out any excess moisture. Hold the cartridge by the sides and wipe the copper-colored contacts until no excess ink is present. Place the cartridges with the nozzles facing up on a clean sheet of paper. Repeat this for all of the cartridges. Then clean the copper contacts inside the printer. Let dry for 10 minutes and then reinstall the cartridges and plug in the power cord. Do the complete alignment.
If the problem persists, try new ink cartridges followed by resetting the printer (preferably you should reconnect at an outlet on a different circuit). The reset procedure: turn on the printer and then remove the power cord from the printer. Unplug the power cord from the wall outlet and plug in directly at a different outlet. (no power strips, surge protector or extension cord) Load the paper tray with plain white paper (letter or A4). Plug the power cord into the printer. Turn on the printer and do the complete alignment again.
If this step doesn't solve the problem, then the printer needs service. It is not keeping the alignment in memory.
Refilled or remanufactured cartridges can be involved in the problem. The printer usually remembers the alignment when a cartridge is removed and reinserted. Clogged nozzles on an ink cartridge can also be involved.
I hope this helps.
(for pictures and more details see: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336348&cc=us&lc=en&dlc=en&product=428800&tmp_track_link=ot_search )
Oct 22, 2010 | HP PSC 1510 All-In-One InkJet Printer
Every time I turn on my printer, a Dell 948, it prints a page
Hi
We have 30+ printers... which we use for testing empty inkjet cartridges prior to refilling with ink. Basically we inject a little Magic Inkjet Flush directly into the dried print head which allows us to unclog them. Then we soak them overnight on Magic Pillows which gives just enough to do a PRINT TEST next day.
As some of our printers always try the alignment test here´s what we do...
1. Pull paper stack slightly away from printer, when it tries to print it thinks it is out of paper and should offer a cancel print option.
2. Alternatively if you print daily? Try leaving your printer power on... Some do alignments every time you power up... so dont switch off (they use very little power in standby.)
3. When exchanging inks like HP immediately switch off printer which cancels the print test. Then just switch on again.
4. Reinserting your printed sheets each time will save paper if not ink.
Good Luck!
Tinteiros (Ebay)
Mar 22, 2009 | Dell 948 All-In-One InkJet Printer
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
How do you change an ink cartridge on a HP officejet 5510 printer?
Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Aug 11, 2008 | Office Equipment & Supplies
Prints only slight blue
See my previous posts about intensive cleaning and you should be good to go again: http://www.fixya.com/support/t138226-printer_not_printing
Jun 17, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Brother MFC-210c prints some lines blurred, letters stacked - alignment ok.
i have the same problem. repeated cleanings seem to help, when i print large fonts they come out pretty clear, but the smaller the font, the worse the blurring. 600 DPI prints mismatching patterns, but 1200 DPI prints perfectly fine. so i have found that printing on "fine" quality instead of "fast" or "normal" quality improves print quality ALOT. it uses more ink, but i am in business and need to be able to read very fine print!
May 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
The black cartbridge is not printing and won't align
Dies this model have a separate print head? Or is the head part of the cartridge? If it is the latter then it seems to be a data transfer problem- which means possibly the contacts in the machine that mate with the contacts on the cartridge are dirty or damaged. In the first instance try gentle rubbing with a moist tissue the in machine contacts then try. Also try the Lexmark website Tech Support Team.
May 20, 2007 | Lexmark X6170 All-In-One InkJet Printer
HP LaserJet 1020 Printer Logo
197 people viewed this question
Seeker5211
Seeker5211
