I have a siemens 200 amp main circuit breaker that bolts on. After the ice storm we had in nh a month ago, i can no longer turn the main breaker off on the panel. It moves but does not stay locked in the off position, it just returns to the open position when i let it go. Is there a quick fix or must it be replaced???
    Sniper:
  • 51 Answers
Move the breaker all the way on and all the way off and if it still wont stay in place it must be replaced.
Posted on Jan 09, 2009
How do I lock out a 200 amp Siemens circuit breaker ?
Check garvin Industries website. they offer a multiple of different lock systems for breakers
Aug 23, 2017 | Siemens Electrical Supplies
Reset instructions for a wls2f320 main breaker
Turn off all other breakers. And try reset again.
3-phase solid state breaker from Siemens
Contact siemens:
http://www.siemens.com/entry/cc/en/
Unfortunately the Siemens site does not show results for WLSF320, but has results for solid state circuit breaker:
http://www.siemens.com/corp/apps/search/en/index.php?q=solid+state+circuit+breaker&lang=&site=siemens_c_ww&lr=lang_en&as_filetype=&client=siemens_f_ww
Otherwise I cannot find .pdf file to help more.
Jun 09, 2013 | Electrical Supplies
Main breakers keeps blowing what is the reason i had the electrical company check there stuff up to the house said everything was ok no smaller breakers are blowing just the 200 main is it possible i did...
Add up all the amps from active breakers. Do they add up over 200? If not, then I suspect a bad main breaker. If they do, then you need a larger service box and or main breaker.
Sep 24, 2017 | Siemens 200 Amp Main Breaker 30 Spaces 40...
We need query regarding new installation of 6.6KV circuit Breaker. can u give me phone number or address of concern person or dealer or siemens customer care
Hi, please find it at below : http://www.energy.siemens.com/hq/en/business-portal/
For more information please contact our Customer Support Center:
Phone: +49 (0)180 524 70 00
Fax: +49 (0)180 524 24 71
(Charges depending on provider)
(From the German fixed network € 0.14/min.
and from the German mobile phone networks
max. € 0.42/min.)
Siemens AG
Energy Sector
Freyeslebenstrasse 1
91058 Erlangen
Germany
Jan 20, 2011 | Siemens 200 Amp Main Breaker 30 Spaces 40...
Lights get bright then dim over and over can hear buzz noise from box where the main is
Sounds like a loose connection or overloaded breaker, Please call a Electrician due to high voltage in box
Dec 20, 2010 | Siemens 200 Amp Main Breaker 30 Spaces 40...
Siemens main breaker won't shut off. It's a 200 amp breaker. When I throw to the off position, andeven if I hold it there, it just springs back to the on position. The lights in the house of course remain...
the breaker needs to be replaced, sometimes you could take the back of a screwdriver and tap the front of the breaker and that may help release the mechanism but more than likely you will have to replace
Aug 29, 2010 | Siemens Main Breaker Load Center 200 Amps
Siemens Main Breaker 125 Amp gets warm and trips
sounds like a loose connection ,or possibly a weak main breaker.
Jul 14, 2009 | Siemens /ITE 100Amp 2-pole molded circuit...
Not all Breakers in Breaker Box working,
POSSIBLE THE BREAKERS ARE WORKING AND THE NEUTRAL IS OPEN , MOVE ONE OF THE WIRES FROM A BREAKER YOU KNOW TO BE WORKING ,THEN REPLACE IT WITH ONE THAT IS NOT IF CIRCUIT COMES UP THE BREAKER IS NOT WORKING IF IT DOES NOT THE PROBLEM IS THE NEUTRAL WIRE FOR THAT CIRCUIT MOST WILL BE WHITE WIRES ENTERING PANEL , IF THE BREAKER ALTERNATE WORKING MOVING DOWN THE BUSS SAY #1 WORKS #2DOESNT #3WORKS #4 DOESNT ECT ON THE SAME SIDE OF PANEL YOU HAVE A DEAD BUSS ,CAUSED BY BAD MAIN OR THE FEED FROM METER BASE ,THEN YOU SHOULD CALL ELECTRICIAN
Nov 15, 2008 | Siemens 200 Amp Main Breaker 30 Spaces 40...
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
