Question about HP Officejet J5780 All-In-One InkJet Printer
I have an hp officejet j5780 all in one and am struggling to get it setup for the 1st time. Installed cartridges & following the alignment procedures. 1st part where it prints from the bottom tray is fine but when it tries to align the top sheet feeder it fails??
  • juliedg Jan 17, 2009
    1 : I print the page alignement -> OK
    2 : I put the printed alignement page in place for scan but I have the message : failure in alignementThe page aligneme.
    For the moment I can print documents but I have problems with scanning and coppy
  • juliedg May 11, 2010
    I did that. I din't have the problme with the message of alignment.
    But the scanner does'nt work.
    Si I try to reinstal the software.
    Now I haven't the message about the cartridge aligment.
    The print works. But I have the following message when I try to scan an image :
    Une erreur s'est produite lors de la communication avec le périphérique de numérisation. Vérifiez que le périphérique de numérisation est correctement connecté et réessayez
  • 8,637 Answers
Normal 0 Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Scanner failure align the cartridge
To Align the new ink cartridge
The HP All-in-One prompts for an alignment of the cartridges every time a print cartridge is installed or replaced. Follow these steps to align the print cartridges from the control panel.
  1. Load unused, plain, white letter, A4, or legal paper into the input tray. note.png
    NOTE:If colored paper is loaded in the input tray when the print cartridges are aligned, the alignment will fail. Load unused, plain, white paper into the input tray, and then try the alignment again.
  2. Press Setup.
  3. Press 6 to select Tools.
  4. Press 2 to select Align Print Cartridge.
    The unit prints a print cartridge alignment sheet.
  5. Load the alignment sheet print-side down and top first in the center of the document feeder tray, and then press OK.
Dec 07, 2014 | HP Officejet 4355 All-In-One InkJet...
Just got new catridge refilled and it only did two documents now says replace HP Office Jet J5780
Sounds like the refilled cartridge chip is not good, take back to where it was filled and get another cartridge
Feb 08, 2013 | HP Officejet J5780 All-In-One Printer
HP Officejet J5780 all in one Alignment problem cartridge will still not align after I've gone through the alignment routine. Cartridges are genuine HP and fairly new
Usually the yellow is the culprit. Dab the cartridge on a paper towel and see if all colors make a spot or line. if any color is missing it will not pass alignment, and you need a new cartridge.
Dec 30, 2009 | HP Officejet J5780 All-In-One InkJet...
Hello! Copies are very poor. New ink. Copies
Try to align the cartridges again...
Steps to align : press the setup button.. > go to tools > align cart and clean cart
Oct 19, 2009 | HP Officejet J5780 All-In-One InkJet...
I insert a new print cartridge and align it as asked. But the printer says it won't align. I have an HP officejet J5780 all in one. Thanks.
Several Steps to take.
If all else fails try a new or different cartridge before you get too carried away looking at the printer for the problem.
1. Turn off the printer and unplug it from the power source for approx. 30 seconds (some units take this long to bleed the power out of the unit).
2. Plug in the printer and step thru the start up procedure (turn it on what ever - not the set up program).
3. Retry the cartridge alignment procedure.
4. If alignment still fails verify that the cartridge electrical contacts are clean and the jet opening is not blocked.
5. Reinstall after cleaning and checking.
Aug 21, 2009 | HP Officejet J5780 All-In-One InkJet...
Hp officejet v40 printer
I'm not sure if this will help but I aligned my cartridge's 5 times then the red exclamation point light stopped to do this hit the setup key #5 (maintenance) then hit # 2 follow instructions... to print full menu settings ..setup #1 then # 4 follow instructions
Jun 15, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
HP Officejet J5780 : copy's and scan's result : black page
Try to disconnect the power cable from the back of the unit and reconnect it after few secs. The alingment will start itself. Complete the alingment once.
Jan 26, 2009 | HP Officejet J5780 All-In-One InkJet...
Replace ink cartidge
Here is a link to the Setup Guide. Go to Step 5 for instructions for ink cartridge installation.
J5780 Setup Guide
Dec 07, 2008 | HP Officejet J5780 All-In-One InkJet...
HP Officejet J5780 All-In-One InkJet Printer Logo
87 people viewed this question
Ben Johnson
