Question about Acer AL1715 17" LCD Monitor
SCRAMBLING SCREEN CAN ANYONE TELL ME WHERE I CAN BUY THE VIDEO BORD FOR MY ACER AL1715 ITCOMES ON FOR ABOUT 15MIN. THEN STARTS TO SHOW SMALL BLOCKS OF MANY COLORS THUS SCRAMBLNG THE WHOLE SCREEN
    Problem Solver:
  • 9 Answers
Befor replacing,make sure settings in video output from video card are set for that monitor.If color quality is set too high or resolution settings not supported by the monitor are used picture may not show up at all.(try safe mode,Settings are usually at bare min.in safe made)
Posted on Jan 26, 2009
Hi i got a acer aspire 5585wxmi since 5 years. but reccently it started showing horizontal lines and distorted graphics, but it works fine with external display. can anyone tell me that what the problem...
thats real strange symptom,really not logical at all,i guess the screen must be the problem perhaps its just tired or has been pressed or pressured unnecessarily,you can buy replacement screens there widely available.
Mar 10, 2011 | Acer Aspire 5500 5570-2609 Laptop
Where can I buy an Acer AL1715 monitor from, I have checked ebay and many price comparison sites but no luck =(
Hello frebib, I found one on on EBay from a top rated seller. Here is the link: Hope this helps! Edward
Aug 24, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Cant close the Menu Box from the Monitor
More like to be bad Flash ROM in the logic board is scrambled (not much you can do unless the firmware can be reloaded). You can try looking inside for such thing as bad caps on the logic board and the power supply/inverter board just for luck.
http://s807.photobucket.com/home/budm/allalbums
Apr 18, 2010 | Acer AL1715 17" LCD Monitor
My acer al1715 has a pink tint. It started
This is a low-end monitor and the image processor is failing. You will require a replacement but since the monitor is low-cost, it is cheaper to simply by a new one.
Jan 20, 2010 | Acer AL1715 (Black, Silver) 17" LCD...
Not getting signal from pc. showing acer screen only
try to disasemble the video card then clean it then put it back again then open it...
Nov 08, 2009 | Acer AL1715 17" LCD Monitor
Acer al1715 main board is a problem
shop jimmy on E bay send him an email question
Jan 31, 2009 | Acer AL1715 17" LCD Monitor
My ACER AL1715 is doing something wierd: when I boot it up, the desktop comes up and another desktop appears about 3/4 of the way down the screen. When I open the Messenger, it wraps around so that part of...
It sounds more video card/driver/settings related.
Try setting the resolution to 1024x768 intially. It may help to find the optimal resolution settings for that monitor. Max resolution on it seems to be 1280 x 1024 / 75.0 Hz.
Still seeing double? Try updating your video card drivers.
Still? Try installing the LCD driver. While I've never had to do this, it may be an issue with this model. For XP, select your model here: http://www.acerpanam.com/synapse/forms/acerdrivers.cfm
Nov 30, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 Monitor - screen distortion, discoloration, several times each day
Certain versions of the Acer AL1715 monitor had a problem with the VGA socket. Specifically, the plastic case around the socket was not wide enough. The plastic lip interfered with the plug and so the plug does not seat properly. This causes all sorts of intermittent problems. The version of the AL1715 with the problem with had the UPC code of 0 99802 19889 3. I fixed several of these monitors by shaving off the excess plastic with a Dremel Mototool. A hand file would probably work as well. You have to remove the plastic back to get the clearance to do the job.
e82875f5-b8a2-4548-9fdb-e60e2a37e9f1.jpg 14e1c79c-dd10-4643-b23c-053cfb0678e4.jpg fcd3ba29-2571-453c-838f-32c7fa61078d.jpg 038eb9e5-53a2-4fa0-88b9-56eb63be9378.jpg 19ef87e5-fc9a-423a-af2e-b0d949b0e884.jpg 092e022f-c3ac-4aa4-86ff-99eaa0075f07.jpg fe6adb60-288d-425f-9d35-156c724a2285.jpg
Oct 30, 2008 | Acer AL1715 17" LCD Monitor
ACER AL1715 POWER SUPPY BOARD AR577 VP-583 TURNS OFF AFTER START UP
I have an Acer 1715 that also turns on, then goes dark after a few seconds. The capacitors on the AR577 supply/inverter board were good, but I replaced them anyway. There is a good write-up with photos at:
http://www.electronicrepairguide.com/acer-al712-lcd-monitor-repair.html
This shows the board nicely and capacitors for the 1712 Acer, which is very close to the 1715.
This didn't cure my problem, and after chasing signals, I believe the problem is a bad inverter chip. The SG6841SZ on the back side of the board is a 20 pin gull wing surface mount package that drives the FETs to switch voltage off and on to the high voltage transformer. I know the diodes and FETs work because it comes on. The transformer drive stops when the backlights go out, though the voltages are all there. The 5V drive signal from the control board is there, so the problem has to be the inverter, or all 4 FETs.
If I can get hold of the part and it fixes it, I'll post it here.
Jun 16, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 17" LCD Monitor Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
