Question about Amana ALW780QA
Washing machine will not stop filling
My washing machine wont stop filling up. Thus causing flooding. what can i do ?
    Sergeant:
  • 236 Answers
Somewhere attatched to the tub/lower water hose is something called a pressure chamber- this will need cleaning out. its identified by a plastic/rubber tube leading from it to a higher switch/unit. in the first instance you can blow some compressed air down the tube to see if that helps. it seems that you may need to do more hot washes. remember isolate machine.
Posted on Jun 04, 2007
When i checked the intake and found it clean, I noticed a tube running running from the bottom of the bowl to the water level swith location.
I removed this tube and blew through it and found it had perished.
This tube is a air pressure switch which turns the water off.
Solution
Cut ends of tube and reattach.
Fixed in less than an hour.
Hope this helps
Jeff
Posted on Jan 12, 2009
This isnt a suggestion just a reply this information was quiet handy for me as i had the same problem thinking i would have to get a repair man or a new one the only difference with mine was the hose somehow managed to come away from the chamber at the bottom. i turned the washing machine over and put it back on. hurray washing machine fills at the set level and finally have a working machine again
Posted on Jul 24, 2007
Washing machine won't stop filling
That sounds like the water supply solenoid valve has failed.
Jul 31, 2014 | Whirlpool Washing Machines
E20 aeg washing machine
Sounds like water leak under machine, Polystyrene Float switch activated keeping pump on thus avoiding flood.
Nov 26, 2013 | Washing Machines
Washing machine wont stop filling with water even on small load it floods my floor
If you have a problem with your washeror dishwasher continuing to fillwith water after the valve has closed, then you this tip will help youunderstand why that is happening.
Here is a tip that will help you...
Washer orDishwasher Fills with Water when off
heatman101
Apr 20, 2011 | GE Washing Machines
The fill cycle on your washer is controlled by the pressure switch. That's the component inside the console that has a (either rubber, or clear vinyl) hose attached to it. Its function is to respond to the air pressure associated with water filling the tub, by closing a set of electrical contacts and allowing the machine to go into the wash mode. If the air hose becomes clogged with debris or lint, the signal won't reach the timer, and the machine can overfill.
To determine whether this is the cause of your problem, set your machine on the smallest load setting and watch the fill. As the water exceeds the level you're accustomed to, unplug, or turn off the machine. If it stops filling, the problem is probably a clogged air hose. Disconnect it from the switch and blow through it until you can hear air going through (make sure you drain the machine, first). If it continues to fill after the power is disconnected, the problem is not with the level switch, or the air hose; instead, it's fouled water valve.
The water works by opening and closing by solenoids (one solenoid for each water temperature). When sediment from the cod water accumulates in the valve's inlet, it can foul the valve seat, and it will stop closing all the way. If it gets bad enough, it can cause a flood.
There's really no good way to clean a fouled water valve. It will have to be replaced.
Dec 23, 2010 | Washing Machines
Wont stop filling
if the unit is not flooding the floor pull up the drain hose to the high part of the control panel.make sure to pause or turn the unit off let the water drain out of the hose when it has stopped the restart your machine.
if the unit is flooding then you need to check the pressure switch
Apr 10, 2010 | Washing Machines
Water will not stop filling wash basket, even when off
Your water fill (mixer) valve is failed in the open position.
CLICK HERE for the part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 20, 2009 | GE WBSE2090A Top Load Washer
Washing machine overflowing
Sounds like the water level sensing sub-system is malfunctioning. If you want to pursue this further, let me know.
Apr 29, 2009 | Siemens WFXD8400UC Front Load Washer
Samsung Silver Care washing machine
Sounds like your inlet valve is stuck Open ( meaning it wont shut off incoming water ) That may be defective or the control to it may be at fault.. Try unplugging the washer ..and see if the water still continues to fill up the drum? If that happens, then your valve is probably in need of replacement.. Typically, when de-energized..they close and stop water from entering the system.. Hope that helps
Aug 18, 2008 | Washing Machines
Washing Machine Wont Fill and cycles unresponsive, Help :/
Sounds like your control board is shot. Do you have 120VAC going into it?
Oct 30, 2007 | Washing Machines
Open Questions:
See all Amana ALW780QA Questions
Washing Machines Logo
134 people viewed this question
Top Amana Washing Machines Experts
Sal De
Mike
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
