Question about GE DBL333EA Electric Dryer
GE dryer DDE5300 runs only if you hold start lever- burnin smell from motor, Is there a start switch on motor?
  • GE Master
  • 8,220 Answers
Broken belt. The safety switch will not allow the motor to stay running if the belt is broken. Open the door and look up at the 12 oclock position and their will either be 2 or 4 screws holding down the top. These must be removed and then you can get the top to come up(or off on newer models). Once you have the top up you can get to the screws which hold the front on (2). Then you simply remove the front and get it out of your way. On some these dryers there is a friendly rear hatch to help you replace the idler.
Posted on Jan 09, 2009
Hey, Thanks for the help! I had the exact same probelem, so I followed your instructions and got to the belt. But it was still in great shape. So I looked a little deeper, since you were sure it was a belt problem. And sure enough, the thing (drum?) that drives the belt had a sock stuck in it!!! So, you were pretty much right on! If it weren't for your post, I would have probably just bought another dryer, since a repairman costs as much as a used dryer.
So people, if its not the belt, don't stop there, while it's all apart, look for socks!
Posted on Feb 07, 2009
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
Why does dryer only runs as long as start switch is depressed?
You give no information regarding make or model, but I believe you will find that the "run switch" on the motor is not working. This is a centrifugal switch located in or attached to the motor. With make and model, one could track down the part and replace it.
May 08, 2014 | GE GTDP300EMWS Dryer
When I the start the GE dryer it will not start unless I will Hold it to On position. when I release it it will stop.in other words it will not hold to Run position
you could have a bad motor. the motor has an internal switch that is stuck in the start position and not switching to run. replace the motor.
Feb 05, 2011 | Dryers
My general electric dryer DDE5300 is no longer warm so clothes don't dry, though it runs. How can I tell if its the heating element or the thermostat?
You Will have to use an ohm meter and the tub has to be taken out. You can on a GE open the door and push in on the door switch and starte it with the door open and look straight in and see the heater come on but if either the heat element of thermostat is out the element wont come on. If you live in ahouse with fuses instead of circuit breakes or a fuse box between the dryer and main circut box check the fuses an electric dryer will run on one fuse but not heat if this is the case switch the fuses and see if it runs if not one fuse is bad.
Apr 21, 2010 | Hotpoint NVL333EY Electric Dryer
Electric / gets hot shuts off,has burnining smell
This sounds like you're having a problem with the Dryer motor. Have you tried letting it cool down, and then running it on a low heat or fluff air cycle? Try this and see if you still get that burn smell. If you do, which I'm pretty sure you will - then you most likely have a bad motor. If this is an older dryer, then I'd look into getting a new one (or used). I just bought a nice (used) dryer and washer for $250.00 for the both of them. And they delivered it too. So you'd probably be able to purchase just a dryer for about $125.00 on the average from a discount appliance store. It'll cost just as much or more, to have a repairman come out and replace the motor. I hope I was able to help. If you have any further questions, feel free to contact me again. Best of luck to you! - Jim
Mar 29, 2010 | Kenmore Dryers
Dryer will start but will stop when you let go of start switch
the most common problem for this is a sticking motor switch. the switch is mounted right on the motor and has a centrifical lever that tells the motor if it should be starting or running.
lint will build up under the switch lever and cause it to not move.
take and remove the lint with a vacuum or an air hose. if this doesnt solve your problem then you may have a stuck contact in the switch itself. no sorry the switch is not available seperately. you might have to replace the motor.
Mar 29, 2009 | GE DBSR453EBWW Electric Dryer
Dryer switch grinds and sometimes starts, most times not
Sounds like the overload switch is cutting out , my gues will be that the motor is going bad. Just replaced mine was doing the same thing.
Jan 20, 2009 | GE DBL333EA Electric Dryer
I need to replace the drum bearing on my GE DDE5300 dryer
The idler pulley controls the tension on the belt. Simply grasp the idler pulley located by the motor and pull in the direction of least restraint, then slip the belt off the idler pulley.
Make sure the power is disconnected to the dryer. Below is a link that will assist you with exploded diagrams and parts information.
http://www.repairclinic.com/0100_20.asp
Good Luck!
Dave E. (Illeagle)
Jun 15, 2008 | Hotpoint NVL333EY Electric Dryer
Dryer
drcool is right, we need to know what type of dryer, but is sounds like the centrifugal safty switch is bad and that is why it was not reamining running after you release the start button. Some dryers it is seperate from the motor, others it is in the motor, that is where I would start testing and see if that switch is bad. You really will need a wiring diagram to truly trouble shoot it, and most dryers have them somewhere inside the covers.
Feb 12, 2008 | GE DCSR483EA Electric Dryer
GE DBL333EA Electric Dryer Logo
340 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
