Question about Kirby Generation 3 Bagged Upright Vacuum
My kirby won't work
Iwas using the vaccum and I smelled something funny, it wasn't a burnt smell, but more of a perfumy smell. I then turned it off and changed to the hose attachment and it would not go on. It has a brand new power cord. The power light does go on, but nothing happens.
  • Dawn Marie Nov 27, 2012
    It is NOT the belt. It does not work with the HOSE OR the brush attachment.
    New Friend:
  • 104 Answers
It is the rubber belt that spins the brush. It must have worn out. Buy a new one.
http://www.amazon.com/Kirby-Cleaner-301291-3-Generation-Ultimate/dp/B0014SQVKK
Posted on Nov 25, 2012
SOURCE:
SOURCE: Vibrating and noisy Kirby
Power off the vacuum.
Unplug the power cord from the wall.
Remove the head or hose attachment.
Look at the fan and make sure all the fins on the fan are there.
If part of one or more is missing it will cause the fan to wobble and shake.
Posted on Oct 19, 2007
dthompson
  • 98 Answers
SOURCE: kirby attachments instructions
Ok, the hose goes on the front. The light should lift up then, the front emblem rotates. this releases the belt from drive shaft. Underneath where the light was, there will be a release lever, which will release the entire front end where the brushes are located.
Once removed, you will see the intake fan and bar beneath it. The hose hooks to this bar. Then to the left of intake, there is a safety switch. The end of the hose has an arm that will fit into this safety switch.
Once hose is in place, the release lever that loosened the brushes will now tighten the hose.
The bag stays in the same place. If you have the 2nd handle attachment, you can use that to replace the upright handle. The release button on back side of handle.
I own a G4 and used to sell the G6 which was right before the one you own. The G3 thru Ultimate G are work in the same manner just different colors.
Hope this was helpful.
Posted on Apr 22, 2008
Agent Don
  • 310 Answers
SOURCE: I have lost My Kirby G5 Manual
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=11561&thid=539967
Posted by Marie1231 on Apr 23, 2008
Kirby G5 Bagged Upright Vacuum
I need to know how to use the attachments that came with the Kirby. I know how to use the shampoo/vacuum, but not the other attachments or the upholstery cleaner. Does anyone have any idea?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
1st, you need to un-hook the lever @ the top of the Kirby head, dial off the belt from the Kirby Vacuum Head using the Kirby emblem in the front of the vacuum, that also serves as a hook/spoon to dial the belt off the fan pulley. Once you have removed the vacuum head you now hook up the attachment hose to use the attachments by locking the attachment hose to the top lever. All regular Kirby attachment will fix on the attachment hose end including the spin brush if you have one with your Kirby --- using the Kirby Shampoo spray the soiled area and use the spin brush to agitate the carpet and or upholstery, try not to use to much water. If you have a Kirby shampooer – use the recovery tank on the exhaust port of the Kirby (this means that the cloth/paper bag needs to come off and install the clear recovery tank. Please refer to the Kirby owners manual for any type of trouble shooting that you might need – or please feel free to contact your local vacuum dealer in the yellow pages or contact your Kirby factory manufacturer listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 23, 2008
SOURCE: smells (burnt rubber) like it's overheating when I vacuum
I would check the brush roller and make sure it turns good and replace the belt on it . When you smell burning rubber most of the time it is the belt .
Posted on Feb 24, 2009
  • 36 Answers
SOURCE: My Kirby G4 won't turn on. Everything is engaged
It could be a few different things. First make sure the emptor tank on the side of the unit is pushed all the way closest to the unit. ck to see if light comes on (that will tell you if you have power to the unit.) if so It is an internal problem. Or it might be, what is called the power foot switch. It's kinda of like the brain for the kirby there are 3 saftey switches built into it. they must all be working at the same time for the unit to power. If need be take it to a vacuum repair shop one with free estimates. this way they can diog. the problem and give you a repair cost, if need be. Hope this helps.
Posted on Nov 14, 2009
I'm having aproblem with my kirby g5 vacume i'vereplaced the gaskets and i can still smell dust when i use it
Did you try vacuuming out the inside of the cloth bag? Or washing it? Many times the dirt makes its way out of the paper and back into the room through that cloth bag.
Feb 11, 2013 | Kirby G5 Bagged Upright Vacuum
Brushes not rotating on kirby vacuum
Change the belt, they stretch after while. If it made a burnt rubber smell or it's > 1 year old this is probably your problem.
Here's what you need:
http://www.vacuummedic.com/product.php?id=279
Good Luck!
Vac Dr.
Oct 15, 2012 | Kirby G4 Bagged Upright Vacuum
Is it worth trying to fix my kirby vaccum?The motor smells like its burning when we run it
Generally the smell is the rubber belt that attaches from the motor to the brush.
Make sur the brush rollers are clean and spin freely, check the belt at the same time.
Please let me know if this helps.
Jan 09, 2011 | Kirby Ultimate G Bagged Upright Vacuum
My vacuum was working fine, then started to smell a little funny like something was burning. Turned it off. Now when you turn it on it will run for a few minutes and then shuts off, like something is...
The smell is usually the fan belt. When the brush is stuck in place, the belt spins and burns. Check to see if the brush is free to spin. If the Belt is burnt, it needs to be replaced.
Jan 31, 2018 | Kenmore 28015 Bagged Canister Vacuum
Kirby G4 running very loud and smells hot.
were you put the belt on see if any thing is rubbing against shaft.it may have been the belt,replace the belt and clean out the bab and also the floor brush.
Jul 31, 2010 | Kirby G4 Bagged Upright Vacuum
I bought this second hand, so have no manual for parts, etc. I smelled something really bad, am assuming it was the belt. How do i release the head of the vaccume to get to the roller. It needs cleaned...
rotate the front belt lifter from green to red then rotate the locking knob above the nozzle. and the head will lift off. it helps if you put the height adjustment in the highest setting. did it smell like rubber burning?
Jan 01, 2010 | Kirby G5 Bagged Upright Vacuum
Smells (burnt rubber) like it's overheating when I vacuum
Feb 23, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Burnig smell when vaccumming
check the turbine controlling the brush. else the bearing might be blocked,damaged and burnt.
Dec 25, 2008 | Kirby Vacuums
Burning smell, vacuum wont turn on now
the front of the machine ( the peice that holds the brush roller ) and the bag unit are part of a safety system that will only let it turn on if both are locked firmly in place, after checking that examine the cord, look for any burn marks especially at the plug and where the cord clips into the retainer on the handle and if you can where it plugs into the machine but you will probably need a set of torx screwdrivers for that. if there was any funny noises before it shut off the kids could have damaged the motor, and just because the belt isnt broken it can still get burnt and make a bad smell change them ever six months to a year
Sep 04, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
193 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
