Question about Hitachi Televison & Video
Hitachi 57s500, has power, no pic and has a high pitch squeal
Found some bad solder joints, took care of them...what do you suggest next..thanks so much
    Genius:
  • 2,920 Answers
You may have a bad flyback or transformer you need to check both
Posted on Jan 09, 2009
  • 10,594 Answers
I would suggest.. If you have TV repair experience and know basic electronics then gte service manual of TV and check horizontal deflection area. let me know out come to help you further.
    Sergeant:
    Novelist:
  • 326 Answers
Also check out if any of the capacitor is blowned or bulged up that needs to be replaced.
2000 Impala high pitched squeal, not a pulley
It could be a vacuum leak on the inlet manifold or pipes Start engine and allow it to idle, spray some wd 40 or similar around the inlet manifold & vacuum pipes, if you notice a change in engine speed when you spray you will have found the area of the leak
Mar 02, 2013 | 2000 Chevrolet Impala
Emerson EWF2704. Plug it in and a high pitch squeal is coming from the board. Originally tv had no vertical now it won't come on at all. Thought there were bad solder joints and re heated them but still...
Hi.
The problem is likely the deflection yoke.
Try to understand if the noise is coming from the flyback transformer, from deflection yoke and ferrite beads in the horizontal deflection circuits or from one of the boards.
If the problem is one of the boards, then the noise may be produced by a melting capacitor.
If problem is the deflection yoke, then the most common fault is still a cold solder joint. Rather than randomly heating all joints you need to check continuity (read Ohms to verify circuit is closed) to ensure that the solder joints are fine.
Here a service manual
Jun 01, 2010 | Televison & Video
High-pitched squeal/whistle noise from range
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Dec 04, 2009 | Maytag MGC6430 Gas Cooktop
D52W20 sooner or later baby I WILL watch a ball game
TL010 is more likely. Its a 2SC5588 Transistor Horizontal Output.
Nov 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Headset Pitch
Problems with electronic equipment that exhibits a fault after being switched on for some time can often be traced to a thermal fault. Most usually part of the circuit exhibits high resistance due to a microscopic gap opening up in a component or a defective soldered joint. If removing the jack plug and replacing it clears the fault for a while this suggests that one of the terminals of the socket may be badly soldered. This can sometimes be identified by visual inspection of the joints. Look for a soldered connection which appears as a bead of solder apparently not wetting the circuit track or the pin. If not obvious suggest you carefully resolder all the joints to the jack socket. To get a good joint you may have to clean up areas around existing joints so that the solder wets the metal. Take care not to overheat any surrounding components.
Aug 28, 2009 | Radio Communications
Has power but No Video or Audio
Tries unplug &replug see get it back or must replace the video board might burn parts.
Mar 28, 2009 | Hitachi 57S500 57" Rear Projection...
Hitachi 53udx10b no picture have sound
sounds like to be you have a bad solder joints, check solder and make sure the they are still attached.
Jan 02, 2009 | Hitachi 53UDX10B 53" Rear Projection...
NO PIC HIGH PITCH SQUEAL COMING FORM BACK BOTTEM PART OF TV?
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Model f27650 High pitch squeal
the high pitch squeal indicates shorted component/s. the transformer goes hot co'z its being overloaded by the shorted component, it too could be the one creating the squeal!!
if you have experience with electronic troubleshooting, try to test some of the components particularly on the secondary part of the transformer.
Be careful and make sure the TV set is unplugged.
test for shorted diodes and transistors, if you're in doubt of your readings try to desoldering one leg of the diode then proceed with the testing/measuring. replace any of the bad components you find exactly with same part number or replacements with the same rating.
spend more time on it resoldering some other cold soldered components.
Oct 29, 2008 | RCA F32650 32" TV
Screaming acer!
sometimes if the inverter board (the part that drives the backlight) has a cold solder joint on it, it can actually generate a high pitched resonating sound (aka a screaming squeal sound)
if it's under warranty, have the manufacturer correct the problem.
if not under warranty, retouch the solder points on the inverter board, or have a repair tech fix it for you.
Jun 03, 2008 | Acer AL1916W 19" LCD Monitor
Televison & Video Logo
23 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
