Question about Iwill Computers & Internet
I am looking for the manual for the DVD266-r
Trying to put together a DVD 266-r mother board in a new case. I found the DVD266-u manual but it doesnt match up with some of the connections for speakers, led hd led etc.
  • 43 Answers
Here you go
http://www.motherboards.org/mobot/manuals/IWill/DVD266-R/
post again if you have any more to ask.:)
Remember to rate Ty
Posted on Jan 09, 2009
Is it possible to upgrade the mother board in this computer?
Dell Cases are very often only for Dell boards--connectors not standard--It can be done,but a lot of trouble. If you want to really speed up look for good complete kit from tigerdirect.com--and put it together--Will work A LOT better than what you can buy at stores.
Jan 31, 2014 | Dell Precision 390 Workstation Tower,...
Hello! I have an old p6stmt motherboard that I'm trying to install a pci video card into. How do i disable the onboard video? I've looked at the bios manual and i'm not finding the answer...can anyone...
In most cases, do not worry about disabling the onboard video just yet. Install your new graphics card in the the slot and put the case back together. Attach the monitor cable to the new card and boot the machine. Windows will load a default driver to give you a picture. Windows will then give you a pop up that says it found new hardware. Cancel this operation and all others that pop up. Open your cd/dvd and insert the driver/software disc that came with the card. Run the cards program and let it install it's own drivers. When it is done, remove the disc and reboot. The computer will now go to the new graphics card and ignore the integrated. I never uninstall the integrated because stuff happens and if something happens to the new card, you have something to fall back on in case.
Jun 10, 2010 | EliteGroup ECS P6STMT SIS630ET Chipset...
MANUAL OF MOTHER SYNTAX Olevia Sv 266 M
go to syntax web site download driver and manual jim
Mar 07, 2010 | Computers & Internet
Manual for DVD266-r
Here you go.
Remember to Rate :) Have fun
Jan 09, 2009 | Computers & Internet
DVD 266-r Problem
I'm not the expert that posted the prior link, but I tested the link and it went through with no problem.
You must have an internet conectivity problem. Be sure you are online and can go to other webpages first, then click on the link.
Dvd266 will not power up
Make sure there are only the screw mounts you need in the case cause one at the wrong place can cause grounding and shorting
Jan 03, 2009 | Iwill DVD266u-RN Motherboard
Cyberhome dvd player
ok if you already have it fixed great but if not here is a solution if the other ones that were told didnt work... My sister had the same dvd player it wouldnt load any of the dvds. so she gave it to me. If you dont want to risk what im going to tell you than well u can pay 200 dollars or somthing to get it fixed. Take the top part of the dvd player off. you then take the little disk cover that holds the disk on the player off. if you can push the laser as close as you can to the thing that spins the disk. now if that doesnt work clean the lens by taking prokide or rubbing alchol with a q tip and just rub the lens lightly. it should clean that off. put everything back together and then try it. if it still doesnt work the mother board in it could be fried. if that is the case than well u can get it fixed for no telling how much. if you dont wont to pay anything than throw it away. Hope this helps!
Nov 01, 2008 | Cyberhome CH-DVD 300 DVD Player
DDR SLOTS INSTEAD OF SDRAM
Hello
Betwin the two couples of memory soket it must be ajumper that guives you the abilitie to change over the frequency rate when you change your memory model .
If there is no jumper try to check if they are not using a strap soldered in the mother board then you will need some electronic skills to change over your frequency
Apr 05, 2008 | Intel Motherboard
Emachines problem... PSU works but comp doesnt turn on
Hi, Did you just add the second CD? If you did you may need the driver for the mother board? Make sure the power cord for the cd has voltage plug it into the DVD drive also check the cable make sure red stripe is on the correct side of drive. You can download the driver at http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T-Series&model=T2672 User guide is there as well. The start button has a pair of wires with a small pin connector on it. This will connect to the motherboard if there is a 3 pin set you might try moving to the other pin. The new power supply also has to provide a start voltage? Your power supply may not be compatible or it may put the voltage on the third pin.
Aug 22, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
93 people viewed this question
Top Iwill Computers & Internet Experts
Alun Cox
David
David
wahidmeer
wahidmeer
Level 1 Expert
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
