Question about Mitsubishi WS-55613 55" Rear Projection HDTV
DVD UPSCAILER 1080i
I tired to hook a Phillips 1080i upscailer up to my Mits. I used a HDMI to DVI cable. The connections were good. I selected the mono link for the device. The display read Monolink 1080i standard, but there was no video. I checked the settings on the dvd player by using component video to see what the hell I was doing. As far as I can tell, all the setting were good to go. I disconnected the hdmi part of the cable to see what the dispay would read. It only read monlink. As soon as I pluged it in again and it read 1080i standard. Still had no picture. I do not think the cable is bad. Any thoughts?
  • Joe Smith Jun 04, 2007
    The DVI cable I used was a DVI D. It was for a single signal, not a dual. Does this make any difference?
    Genius:
  • 1,074 Answers
Get a new set of cable and try again if nothing then you will have to get a tech to check your set good luck.
Posted on Jun 04, 2007
When using PS3 on RCA D52W19 TV, the screen does not fit ( it is zoomed and off-center) in 1080i resolution.
hello!
Have you tried to toggle "format" or "screen size"? On those sets non HD and HD settings could be adjusted separately. Try that, first. If no luck, try similar settings on PS3. I bet, you will be able to match screen format there, as well. To me it looks, like picture formats are mismatched. Also: try to use "component" cables, instead of DVI adapter cable, if nothing works.
good luck,
Alex.
Feb 16, 2012 | RCA D52W19 52" Rear Projection Television
Setting up HDMI / DVI port as a selectable Imput
may i know the model and maker of the device you want to use a HDMI cable
Sep 08, 2008 | Hitachi 51F510 51" Rear Projection...
I have a Denon AVR 587 and a Phillips DVD Player. I am trying to figure out how to hook the DVD player up to the receiver without using an HDMI Cable. Also I have a laptop with a DVI connector on it that i...
Get the manuals. All is explained there.
http://www.retrevo.com/support/Denon-AVR-587-Receivers-manual/id/696ci075/t/2/
Component video is just as good as HDMI.
The unnamed Philips DVD player has a manual somewhere. Try retrevo or drill down into this directory to find it...
http://www.p4c.philips.com/files/
Be patient. The alpha directories are slow to load.
DVI connectors can be adapted to HDMI or component video.
"Web search "dvi to component adapter" "dvi to hdmi adapter"
Your PC's video and display controls will determine how all that works.
Aug 04, 2011 | Audio Players & Recorders
Hook up a lg blueray player to mitsubishi medallion 65"
Yes, there is an adapter which will take the hdmi output of the blue-ray and convert it to dvi. You will also need to connect the blue-ray audio out (rca jacks) since the hdmi is both audio and video (digital) and the dvi is video only.
Jan 04, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Philips 60
There will be a big difference in video quality between HDMI and S-Video. If you happen to have a DVD player that uses HDMI you can upconvert your movies to 1080i if your DVD player allows it. The only problem that you might run into is your audio. HDMI has audio built into the cable and DVI does not, with the HDMI to DVI cable you are going to have to find an alternate source for your audio to travel through. If you are looking for video quality get the HDMI to DVI cable.
Dec 14, 2008 | Philips 60PW9363 60" Rear Projection...
Converting up to 1080
Hello. You have to use the HDMI port and connect to the HDMI, or DVI, port on the back of the TV to get 1080. Even if playing HDDVD, this cable is necessary to get the increase. That, and the TV has to be in 1080 too. If you look at the display, on the front of the player, while watching the DVD, it will tell you at what resolution the DVD is playing. The HDMI to HDMI/DVI must be installed to get the increase in resolution. I have a Panasonic HD 34" 1080i widescreen TV, with DVI connection. When connected, the player played my DVD's at 1080i on my TV, while at only 480i thru the composite cables.
On some older movies or series(I like Star Trek- TNG), it doesn't work well due to the transfer to the DVD. Most newer DVD's, such as Batman Begins (there is an HD out, but I have DVD only), improved on the upconvert for me nicely.
Jan 21, 2008 | Toshiba HD-A30 HD-DVD Player
High Def.
If you are using the component inputs it will select 1080i automatically IF that is what it is being sent. Make sure your device (cable/satellite receiver) is set to 1080i. The TV recognizes 480i, 480p(progressive scan DVD player) and 1080i. It DOES NOT recognize 720p. Since it has no HDMI or DVI input it can't do HD DVD or "upconvert" DVD but it does very nicely with 480p/progressive scan.
Dec 24, 2007 | Mitsubishi WS-65311 65" Rear Projection...
Screen flicker when watching 1080i
Component video has a max resolution of 720p. in order to use 1080i or p you have to use hdmi or dvi connections. That is why you get the flicker.
Dec 08, 2007 | Onkyo TX-SR304 Receiver
This TV won't support 1080!
Low or poor signal from the cable company. Try another signal source such as a DVD play.
May 12, 2007 | Hyundai Q320 32 in. LCD Television
Mitsubishi WS-55613 55" Rear Projection HDTV Logo
104 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
