Question about Brother MFC 7420 All-In-One Laser Printer
Paper jam lcd won't turn off
Have gone through the process of opening front, back, etc. No paper is visible, but "paper jam" lcd will not turn off.
  • scargo1013 Jan 11, 2009
    razors:
    Thank you SOOOOO much!! I never thought of looking for stuck paper UNDER the drum unit. There it was, I pulled it out and now everything works great! You are a genius!!
  • 215 Answers
Pull your drum unit out and look at the bottom of it. you'll see an open slot in the center. make sure no piece of paper is caught up in it. if thats not it, open rear of machine and look fpr your black sensor lever. make sure it moves down and springs back into position by manually pressing it down.
hth,
razors
Posted on Jan 09, 2009
Paper jam
Epson stylus paper feeder keeps jamming
Feb 16, 2014 | Epson Stylus Sx535wd
Printer eror code U051
Instructions
    • 1
      Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
    • 2
      Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
    • 3
      Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
    • 4
      Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
    • 5
      Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
    • 6
      Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
    • 7
      Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
Mar 07, 2012 | Canon MX700 Office All-In-One InkJet...
Code error 5100
  • 1.
  • Press down and hold the "On/Off" button, which is located on the printer's operator panel, for one second. Wait 15 seconds and then tap the button again. Attempt to print or scan a document.
  • 2 Check the paper feed tray on the front end of the Canon MX700 to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
  • 3 Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
  • 4 Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
  • 5 Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
  • 6 Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated.
  • 7 Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again.
May 20, 2011 | Canon Office Equipment & Supplies
When the cartridges move to the right there is a hang up of some sort and then error 5100 comes up
Error code 5100 describes a physical problem either with a paper jam or an incorrectly seated ink ink.
  • 1
    Check the paper feed tray on the front end of the printer to see if there is any paper visibly stuck inside the printer.
  • 2
  • 3
  • 4
  • 5
  • 6
    Repeat the process with the other ink tanks, and then close the printer's cover. Power the printer off and then back on again.
  • Feb 01, 2011 | Canon PIXMA MX310 All-In-One Printer
    How to fix error code 5100 for canon ip6320D. it appearing while head cleaning.
    This is either due to a physical error caused by a paper jam, or incorrectly seated ink. To fix:
    Jan 21, 2011 | Canon Office Equipment & Supplies
    I received error code 5100.
  • Check the paper feed tray on the front end of the Canon to see if there is any paper visibly stuck inside the printer. Open the printer cover by gripping the front edge of the printer and lifting upwards.
  • Grab the edge of the jammed paper and gently pull towards you to remove the paper from the paper feeder. Unplug the Canon's power cable and USB cable, and then turn the printer around.
  • Pull off the rear plastic cover tab and check if there is any visible paper jam. Grab the edge of the paper and gently pull toward you until the paper is removed.
  • Push the rear plastic cover tab back into place, and reconnect the power cable and USB cable. Attempt to print or scan another document to see if the error is resolved.
  • Lift open the printer's cover again and wait for the ink carriage to slide into view. Press the "Push" button on the front of the first ink tank. Pull the tank out and then push it back into place to ensure it is properly seated
  • Repeat the process with the other three ink tanks, and then close the printer's cover. Power the printer off and then back on again
  • Oct 11, 2010 | Canon Office Equipment & Supplies
    Paper jam
    The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
    Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
    1. Turn off your printer
    2. Open all trays and remove any paper stuck there
    3. Locate the button to open the printer, open it and remove any paper stuck there also.
    4. Repeate the above step for all buttons that you can find to access the inside of the printer
    5. Close all doors and put back all trays
    6. Turn on your printer
    NOTE: Please rate our help to keep this free service online.
    Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
    Jammed paper the jam is obvious when trying to slide paper drawer in. Jammed Paper is not visible Lifting movable parts does not expose paper
    Dec 07, 2009 | HP Photosmart C7280 Laser Printer
    Canon MP460 Paper Jam
    this is only a possible solution.make sure the paper is between 17  to 24 pounds thick.i once had a jamming problem and it turned out to be the printer which canon replaced under warranty.but in the process i learned paper thickness can make a difference. i was recommended 20 pounds by a staples employee.i hope this helps you.
    Apr 07, 2009 | Canon PIXMA MP460 All-In-One InkJet...
    380 Paper Jam
    There could be a small bit of paper stock in sensor
    near the bypass tray.
    Jun 23, 2008 | Xante CL30 HSE Laser Printer
    Brother MFC 7420 All-In-One Laser Printer Logo
    64 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
