I need to understand how the controls work. I would very much like to access an online owner's manual. I do not want to download a search toolbar to search for owner's manuals. I don't want to download anything except the pdf file that contains the owner's manual. Thank you.
SOURCE: heater will not operate!
did you take it apart to see if the switch is good or the thermostat was functioning? without looking inside, other than saying it don't work, isn't going to solve anything.
SOURCE: Temperature control threshold too high
I have a solution. Let me buy it!! So you can replace it with something that works. I am looking for used
Holmes Heater ModelHFH5506 only and will pay top dollars.
Thanks,
SOURCE: my oil-filled Holmes heater HOH2520U
I had the same problem. this is what i did. unplug the heater. removed the plastic panel to expose the control panel where the blinking light is. Removed all the dust and cobweb build up, then using rubbing alcohol, wiped the white residue that was on the green circuit board. I did this 10 days ago and the heater has been working fine since then. chaz
SOURCE: control panel blinking
my heater did the same, very frustrating. i have solved this problem. i took off the plastic cover to expose the electronic circuit board and noticed that there was a white residue on the board. I wiped this clean with rubbing alcohol and put everything back. as of 3 weeks ago i have used the heater frequently as normal and not had any problems. chazdee
SOURCE: Heater comes on but quickly over heats.
There is no Filter On this Model. Check to make sure there is Dirt in the Flow way of the two towers. if that is not it the back up fuse in the heater is going bad.
