My cannon BJC-2100 series gives me error 5C00 when trying to print
    Master:
  • 413 Answers
The error you are getting refers to the cartridge movement. You need to open the printer so you can see the cartrige and the track it rides on. Make sure that the cartriges can move freely with no obstructions. If the cartridges can move freely and there is nothing blocking the path this will require a pro. If nothing is stopping the movement than another component went out that controls the movement of the heads.
When I looked up the error online it says this is a cleanig error and just to Make sure no obstructions are blocking the cartridge movement, if not needs service.
Posted on Jan 09, 2009
  • Dan rogers
    Dan rogers Jan 12, 2009
    By the rating i am assuming the solution i provided had nothing to do with the printer? i used the information you provided to look up the error code and told you how to fix it based on the error code. I would like it if you would give me the chance to walk you through the steps needed to fix this problem but i do not feel this rating was necessary.
I have canon BJC 2100 printer and a pc with windows 7 OS. how can i have the drivers for the printer in Windows 7? thank you
Go to Cannons' site and download what you need. Some older printers, and scanners do not work with later OSs.
Sep 26, 2010 | Canon BJC 2100 InkJet Printer
I have a cannon printer bjc 2100. It is printing
After replacing ink cartridges, you generally have to perform an alignment routine. On some printers, they have an automatic alignment function, others require the printing out of one or two sheets of paper and a possible adjustment via the service section of your printer software. If this isn't done, you can have an output similar to that you describe.
Oct 24, 2009 | Office Equipment & Supplies
I was given this bjc-2100 printer second hand. I
did you install printer drivers?
is the printer connected to the computer ? via usb or parallel port.
check cartridge
Aug 07, 2009 | Canon BJC 2100 InkJet Printer
Printer not printing
check if the computer see the printer..
if yes.
you need to uninstall all your existing printer driver and then restart your computer and install again the printer driver..
Happy FIXya.
May 25, 2009 | Canon BJC 2100 InkJet Printer
W'ont print
maybe you ran out of ink
Apr 19, 2009 | Computers & Internet
Cannot get printer to print
1. Unplug the printer completely. Move the ink cartridge cradle gently to the left. Over to the right at it's usual resting place you will see a small pad about 1cm square. This pad and the area around should be covered with ink. Get a microfibre cloth and press down on this pad - it's not fixed so should come away with the cloth, otherwise use tweezers gently. Squeeze the pad several times between your thumb and forefinger while inside the microfibre cloth to remove ink build up. Then when not much ink comes out on the cloth, clean the area in the printer around the pad so that looks free from ink too. Then position the pad back in place, move the cradle back into position, plug in and switch on - should work fine now. But it's worth checking for any paper caught near the ink pad as my error occured after a paper jam. Good luck :)
Make sure to clean all the parts thoroughly.
If this does not resolve your issue, let me know.
Jan 09, 2009 | Cannon Office Equipment & Supplies
Printer problem
I found a small plastic "clip" of the type that covers the print-head of a cartridge in the mechanism where the printhead/inkcartridge is mounted. I have no idea where it came from nor how long it had been in there but the printer works OK after I removed it.
Jun 22, 2008 | Canon BJC 2100 InkJet Printer
Vista + cannon BJC 250 = error
Go to
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=329&modelid=6729
and try the XP driver. If this doesn't work, you may not be able to interface this printer to Vista.
Let me know if this works.
May 30, 2008 | Canon BJC 250 InkJet Printer
Bjc 2100 printing errors
Replace the printing head. It's a known problem for BJC 2100.
Jul 26, 2007 | Canon BJC 2100 InkJet Printer
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
