Question about Epson Stylus C88 InkJet Photo Printer
Printer head removal
Printer head needs cleaning
  • 353 Answers
Hi Kenno23 - have you tried a standard head cleaning cycle and nozzle check? If so,what was the result. If not, try it. If you don't know how to, simply right-click the printer icon in the bottom right-hand corner of the screen, and select "Head Clean". After this has finished select "Nozzle Check". Let me know how you get on, or if you've tried all this with no success, let me know exactly what you have tried.
Posted on Feb 15, 2009
Printing will not align
Reinsert printer head
Problems with the printer head of printers might be because the printer head is not secure in its position. The problem would cause the printer head to wobble and produce bad prints. All printer users having problems with printer head are advised to check the seating or the printer head, remove it and then reinsert the printer head if it is not found properly seated.
Clean printer head:
As your printer is used, the printer head might get dust or dirt settlement from the paper being fed into the printer. Dirt settlement would cause printer to produce very poor print quality and such issues can be resolved by carefully removing the printer head and cleaning it with a printer head cleaning solution. However, care must be taken when cleaning the printer head and replacing it back as any damage to the printer head during the cleaning process would affect the functioning of the printer. Brother Printer Support
Oct 16, 2012 | Brother Ink for Mfc-885cw, Lc-1000
Remove mg5220 printhead
Hi I was tried cleaning out of printer head but still not work won't printer look like the printer head need new one??
May 04, 2012 | Canon Pixma MG5220 InkJet Printer
How do you clean the print head?
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Feb 24, 2012 | Canon i860 InkJet Photo Printer
Orange light flashing five times
With the printer on...
Open the lid
Remove the ink cartridges
Lift the print head lock lever on the left
Remove the print head
Gently clean out any ink
Gently clean the copper contacts on the back
Gently clean the print head nozzle(s) on the bottom
Make sure it's dry
Re-install the print head
Put the lock lever back in the down position
Reinstall your ink
Close the lid
Try printing again
The printer may detect that you removed/inserted ink so it may go through a print head cleaning of it's own that you need to wait to finish
If needed, power cycle the printer and then try printing again
You may need to replace the print head
Nov 11, 2017 | Canon PIXMA iP3500 Printer
Errors= head cleaning fault. position fault
head cleaning fault, you need to remove the option for head cleaning.
The position fault may be due to either a wrong label size, wrong detecting sensor selection or your printer sensors needs callibaration
Aug 15, 2011 | Datamax M-CLASS DMX-M-4208 Label Printer
Getting streaking when printing with Canon Pixma MP610. Read somewhere Printer Head needs cleaning, If so, how do you remove It? pkoaktown
Look on your PC. There is a maintenance menu for this printer. Follow instructions to do the head cleaning. If that is not enough you can remove your printer print head and try to clean it with dry cloth or with some kind of alcohol.
good luck
pifonski
Feb 19, 2011 | Canon PIXMA MP600 all-In-One InkJet...
My printer will not print black but is printing all other colours ok
Possible that the B/W cartridge is not contacting or is blocked. remove and fit back. Now remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Nov 02, 2010 | Brother DCP-385C Stylish Colour Inkjet...
Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
5 colors won't print
generally catridge head cloged in case the printer is not in use for a long time,to clean the head chemical is available,alcohol based liquid is used to clean the head.
Feb 08, 2009 | Epson Stylus Pro 9600 InkJet Printer
My Canon ink jets are blocked an need to fix this quickly
Run the printer's Maintenance program and run Deep Cleaning.
Do a print check after each clean as this uses a lot of ink to clean and you don't want to continue after you get a good print result.
Good Luck.
Apr 18, 2008 | Office Equipment & Supplies
Epson Stylus C88 InkJet Photo Printer Logo
210 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
