Question about Ovens
New world twinline 4000 oven - bottom oven door won't shut properly - looks as though the hinge(s) are too slack
  • Anonymous Mar 19, 2014
    door does not close properly
  • Anonymous Mar 22, 2014
    I have an Emilia oven and it won't seal properly at the bottom. I have cleaned it. The hinges are fine.
  • Ovens Master
  • 3,463 Answers
You are right in thinking it is the door hinges that is the cause of the problem .they are non adjustable, so only solution is to replace both hinges.
Plz rate my solution.
Posted on Jan 09, 2009
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
GE JT980 double oven door issue: I have a GE jt980 which I just bought from a cabinet company that used it as a display. It was never used, but when I picked it up, they had taken the upper door off, which...
Make sure the oven door hinges are open fully and locked then reseat making sure the notch on the bottom of the hinges seats on the cabinet locating plate, then release the hinges and close the door....theese hinges can take your fingers off so be very careful
Oct 11, 2017 | GE Profile JT980 Electric Double Oven
Oven door has dropped & won't close properly
You may need new hinges or the door is possibly out of the hinge socket. Try removing door and putting it back in place. These instructions should be in your users manual.
Jun 17, 2011 | Ovens
How to repair hinges on new world oven
Usually doors lift off. You may have to dismantle the door to remove the hinges. Take one to a supplier to get the right hinge.
Jan 03, 2011 | New World G90m Gas Double Oven
Seams to be a lot of steam/ vapour in main oven. when you open door cluds of steam escape. This is the 4000 twinline all electric model.
I have an electric oven and the same problem: loads of steam when I open the door. Plus roasting is a problem, the pan fills up with water and needs to be drained so things are stewing and not roasting. Have spent ages trying to to find a solution so would also appreciate any advice.
Oct 17, 2010 | Ovens
Door does not fully close Door will not rest in the half open position Door looks low since we took it off for cleaning
It sounds to me as though you have not relocated the hinges back properly in the hinge guides. I suggest you remove the door again, and relocate the hinges, make sure that you have them all the way in the hinge guides.
Dec 09, 2009 | Miele Novotronic H350-2B Electric Single...
My oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Sep 16, 2009 | Stoves 720EF Electric Double Oven
Slack oven door on Tecnik 8085
The hinges cannot be adjusted, the only solution is to replace both hinges.
Plz rate my comments.
Jan 05, 2009 | Tecnik Ovens
Neff oven u1420
Hinges not fitted properly,or possibly wrong hinges
Nov 03, 2008 | Neff U1661 Double circotherm super...
Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
Mar 10, 2007 | Miele Novotronic H350-2B Electric Single...
Ovens Logo
331 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
