Question about Bosch Axxis WTA 3510 Electric Dryer
Bosch wta3510us tumbling NOT heating. Reset button?
Is there a reset button? Where?
How to check the heating element?
  • 3 more comments
  • Anonymous Apr 04, 2009
    dryer is running but not heating.Is there a reset button?
  • SFDee Apr 06, 2009
    I have the same problem and the problem keeps repeating, so I have to keep re-moving the panel to push the red button down...is there a long term solution? Do I need to replace the thermostat and or the red button? Thanks.
  • Anonymous Apr 07, 2009
    The "red button" fix is a common problem and has been for two years. The sensor in the door is one problem. The other one is that there is a break in one of the heating element coils which was causing mine to trip multiple times towards the end.
  • barbarabr537 Oct 06, 2009
    the dryer seems to heat but cuts on and off
  • Anonymous Mar 16, 2014
    reset button for heat element
    Problem Solver:
  • 16 Answers
Remove your back cover ,and then you see the heating element.On one side or on top there is a termostat(Small Black)there is a red button which you should press down until you hear a click.Start machine and element should work.You can start it for a little while but be careful.Put cover back after cleaning loose lint etc. Jan
Posted on Feb 13, 2009
White knight 427 not heating
Heating element is probably burned out. Or the thermal fuse / cutoff. I would check the fuse first as the heating element has 2 independent heating coils and usually both won't burn out at the same time. It would be best to have a meter tester. I am in Lake Worth, Fla. I travel within a 40 mile radius How to Replace White Knight Tumble Dryer Heating Element Heater...
Sep 12, 2014 | Dryers
Bosch dryer will not heat
If you have a Tumble Dryer that is not heating up but the drum is turning ok, then the chances are the thermal overload cutout has tripped. Bosch dryers have a reset button but you will have to remove the heater cover panel to access it, you will find it just above the heating element (a black stat with small red button) simply press the red button and if it clicks you've fixed it.
It also may be:
If the dryer doesn't heat, but the drum turns, check the thermal fuse(s). The thermal fuse protects the dryer from overheating and helps to prevent fires. If the thermal fuse is blown, it will have to be replaced
Dec 13, 2013 | Bosch Nexxt 800 Dryer
Tumble dryer wont dry clothes reset button doesnt work
Check the Circuit Breaker. It is a double Breaker Switch. one side is for the heat one for the motor. If that is good then it's possibly the Heating Element or one of the two heat sensors.
Jan 17, 2013 | Dryers
I have a Bosch Nexxt 500 andjust replaced the heating element less than 6 months ago. A week ago it stopped heating up again. Took the back panel off, pushed the reset button but now when I turn it on, the...
Sounds like a bad thermal fuse or thermostat, check all of them with a multi meter for continuity. as for the heater going out I would check ur venting inside and out the machine. the fuses and heater blow out for a reason? Usually due to overheating issues? I suspect ur lint build up is the problem?
Aug 16, 2012 | Bosch Nexxt 500 Dryer
Bosch wta3510us vented stackable dryer. I have reset the High Limit Thermostat and the unit is producing heat and air, although I'm not sure of the temperature of air flow. The unit came with the...
Go to www.repairclinic.com and enter wta3510us. You will be presented with a list of common replacement parts and may be able to view a generic Bosch video showing disassembly. This may help you figure out what's wrong and what has to be fixed.
Feb 28, 2017 | Bosch Axxis WTA 3510 Electric Dryer
My dryer does not heat up I pushed both reset buttons...
Welcome to FixYa.
Just to clarify your statement "dryer does not heat up I pushed both reset buttons..." are you referring to the hi limit cut out ( on the heater box ) and the emergency shut off switches ( next to the belt pulley ) you've reset already ?
examples
I'll assume you are unless you say otherwise since you've also stated the dryer will indeed tumble just not heat, correct ?
Have you checked the heating element for continuity following the reset attempts ?
If not, that is where I'd direct your attention going forward. With the aid of an ohm meter or a multi-meter, place a lead on each element terminal and you should have continuity.
If you're uncertain about how to go about this, send me an email at macmarkus@live.ca and I can attach a short .wmv file approximately 3.5MB ( there is no audio and it is directly from Bosch ) on "how to".
I'll watch for your reply. Good luck.
Regards,
Macmarkus :)
Oct 07, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Dryer wont heat up on a aquarius VTD00, do you think its the element
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. . Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. Also overloading and blocked filters can lead to thermo cut out, it is best to check your manual and call someone out on this occasion. You may even have a red reset button on the rear of your machine some models do, if yours doesnt then call out engineer :)
Jul 19, 2009 | Hotpoint NWXR473EV Dryer
White Knight tumble dryer making a clicking noise when on & has no heat
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
utube.png You-Tube video "XNxE9eXx2Rk" placeholder (do not delete) utube.png
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
May 02, 2009 | Dryers
Bosch Axxis WTA 3510 Electric Dryer Logo
1,697 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
