Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Hitachi 57inch tv 4 years old has a black mark on the screen
The screen has a black mark looks almost like a a paint brush stroke it's 2 inches wide by 10 inches long on the bottom left hand side of the screen bottom on the mark is darker than the top. Does anyone have any suggestions on a fix or what the cost would be to fix it?
  • 2 more comments
  • jsbm1234 Jan 09, 2009
    you can see with the TV on or off & you can see the picture through it so it's not blacked out, I think it may be the screen, but what would have caused it? We haven't cleaned the screen recently and we don't use any spray cleaner just a damp cloth.
  • jsbm1234 Jan 12, 2009
    Is it possible for this to go away on it's own, since we first noticed it on Thursday 1/8 it has gotten a little bit smaller last night while watching TV 1/11 I noticed it was shorted & thinner? I haven't looked at it today to see if there was any difference.
  • Anonymous Jan 18, 2009
    i have black srips gooin to my tv . they go away then they gt bigger its very upsetting how do i fix this so i dont have to pay the eek squad a million dollars to fix this
  • Rusty Larmann
    Rusty Larmann May 11, 2010
    Sounds like it could be in the screen itself if I understand the symptom. Maybe if you describe how dark it is or weather you can see a picture on that section of the screen. If it can only be seen when the set is turned on or if it only shows up on certain backgrounds would also help.
    Novelist:
    Champion:
  • 203 Answers
Thanks for your reply. The only thing that causes marks like that is usually the glue that holds the lenticular screen and the fresnal lens together heats up and drips (or slides) down. There is usually a strip of black tape that seals the two pieces of thin, glass sheets. This allows for easier installation and keeps debris from getting between screen and lens, however, someone overlooked the elements of heat and aging on this tape.The screen and lens can either be replaced or disassembled and cleaned. They are very expensive, (a few hundred dollars each), and disassembly can be very tedious. One caution I must give you is to make sure if you seperate the screen and lens make sure they go back together facing the same way. Try to clean only with warm water and a few drops of a very mild cleanser like dawn. If all else fails, you can buy a used screen sometimes from a local factory authorized service center. Occasionally they save the ones that are in decent shape. I have one 57" screen here in cincinnati that would work. Good luck, Russmann.
Posted on Jan 12, 2009
  • Rusty Larmann
    Rusty Larmann Jan 13, 2009
    From your description of the problem, I think you need to remove the screen and see if anything is hanging down inside. It's pretty simple, just get a person to help lift it off of it's hooks on each side. But first, remove the speaker grill and the row of philips screws beneath screen. Sometimes you must also remove pushbutton assembly, then lift screen up and disconnect any plug connector going to convergence sensors. You should be able to see any debris in the screen by holding it up to the light, or by looking at the tubes and mirror. Let us know if I've been any help, Russmann.
I have black line down right side of 42 inch hitachi lcd tv screen
You have a CCFL lamp that is failing in the panel, time for a new TV
Jan 22, 2018 | Hitachi Televison & Video
Best picture settings for samsung ps50a457p1d
my 50 inch samsung is 4 years old. a black line has appeared just off centre screen. the line is approx.an inch wide and runs from top to bottom. can it be repaired?
Mar 08, 2012 | Samsung PS50A457 50 in. Plasma TV
Lcd tv has black cloudy line from top of screen about 1 inch wide and 4-5 inch long down the screen
This problem is not just for Philips. I've found similar complaints online for JVC, and my Vizio 32" LCD has the same problem. In my case the TV is about 3 years old and has a lot of hours on it.
Oct 23, 2009 | Philips Televison & Video
Red vertical line appears intermittently
you have to have the entire screen replaced. hitachi tried to fix mine twice and couldnt, i finally took them to court and won. want my advice? get a new tv and never by a hitachi again!!! they are the worst!
Jan 23, 2009 | Hitachi 55HDX61 Television
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black opaque line or bar
if its is viewable when off then yes its water or oil.between the screens.these screen don't normally come off from the front.
they have to be access from the rear.
could be big job.
only way to tell is to remove the rear cover.
Apr 13, 2008 | Hitachi 51F500 51" Rear Projection...
51F510 Screen is split in two
requires service, horizontal fold over and possible other problems to come .
Sep 13, 2007 | Hitachi 51F510 51" Rear Projection...
Yellow brush marking on Screen
Your problem is with the blue color,maybe some dirt is sitting on the face of the blue crt and is being projected bigger to the screen,you should try cleaning the face of all 3 tubes,if you familiar with tv service this should help,be careful when removing the back and make sure the set is unplug when you do the cleaning.Let us know how it goes.
Oct 06, 2006 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
184 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
