Question about Kenmore Elite 45986 Front Load Washer
The water level wont shut off .it over flows - Kenmore Elite 45986 Front Load Washer
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Does this only occur on the initial fill for the wash cycle, or does it constantly fill even when not in use?
  • 15,935 Answers
Check/replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
After my toilet fill valve shuts off, water continues sipping into tank slowly. This causes water continuously overflow through overflow tube.
check that the fill valve was installed correctly
adjust the float level so that when full the cistern water level is around 1/2" below the over flow pipe end
what you have now is that the inlet water is not being shut off correctly and the water is still coming in and flowing out of the overflow
Mar 20, 2017 | Washing Machines
WATER WONT SHUT OFF
Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Feb 12, 2013 | Bosch Axxis+ WFR 2460 Front Load Washer
Spin is all that is working, wont fill with water
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jun 27, 2012 | Admiral AAV7000A
Washer wont stop filling and over flowing
To shut the water off, how do you do it? Do you simply turn off the machine at the timer or do you have to turn the water off at the home water supply? If at the machine, check the water level control or the pressure tub feeling this water level control. If you must turn it off at the wall , replace the water inlet valve. If I can help further...
Eric and Ann Campion
P.S. Please keep in mind we help pay our staff with earnings from parts sales. Help us keep this valuable service free and order your parts from us. Visit our website for additional help at http://www.affordableappliance.com or for Parts Order Only, Call 1-570-622-6441
May 01, 2012 | Kenmore 63942 Dryer
Hi hoover 600 mb water wont shut off when it gets to the right level even when i push in the button and un plug it can you help Thanks
This is a failure of the inlet valve if the water flows all the time but if the water flows uncontrolled only when the machine is put on start then it is the failure of the WATER LEVEL SENSOR which is normally a pressure switch.
When the level of water reaches the set level then the pressure of the water will switch on the switch to contact and so give message to the controller to SHUT down the inlet valve.
Jul 07, 2011 | Washing Machines
Cold water does not shut off when washer fills - will over flow - hot water will shut off when washer is full ...
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jan 03, 2010 | Kenmore Washing Machines
Continous water running
just lower your float a little further. otherwise i'd adsume air is leaking out of your float. but if your float is up in the shut off position and water is still coming out. then you need a new assembly.
Sep 04, 2009 | Toto Washlet S400 for Power Gravity...
Kenmore Elite 45986 Front Load Washer Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
