Question about Logitech Wireless Optical Mouse 930616-0403
My mouse will not operate my laptop Red Light is sometimes blinking. Do I need to change na battery in it, if so, how do I open the unit?
    President:
  • 8,637 Answers
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Posted on Jan 25, 2009
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
The charger is plug in and the battery is charging so in my acer 4736 , the blue red is on as the laptop is opwer on and another light is red as the battery is charging , when battery is fulling charged...
try cycling your battery it should be done to lithium ion every couple of months. Run your computer until it shuts down from low battery. Then leave it unplugged for at least 5 hours to make sure all residual power is gone. Then fully charge the battery, this will help fix battery health issues.
May 12, 2011 | Computers & Internet
My Logitech MX 1100 just stopped working out of the blue. The red battery light on top is blinking, so even though I've only been using this for a couple weeks (and the batteries were fairly fresh) I...
I had the same problem, brand new battery, the indicator light still blinking red. I finally got mad enough to shake the mouse kinda hard, and it worked. I then removed and replaced the old batteries in, it started blinking red again, but it worked after I gave it a couple of hard side by side shake. I do notice that there's something moving inside the mouse. It could be a connector that got loose. Hope this fixes your problem
Sep 25, 2010 | Logitech MX1100 LASER Mouse
Have a logitech mouse which I bought in January 2010 and for 2 days now the red light appears and sometimes blinks. . It still is working so far.
the red light is one of two things, either you have an optical mouse and the red light is normal (on the bottum) or your battery is low
Aug 11, 2010 | Logitech Cordless Mouse
Blinking red light on top of mouse. What does it mean?
that is the light sensor that signals the usb pluging from the mouse's attachment so it can operate. When that light quits working replace the battery inside the mouse
Aug 02, 2010 | HP Wireless Optical Mouse
I HAVE A NEXXTECH MODEL;NWKBMCB . WIRELESS MOUSE. I DONT HAVE A DISC WHAT DO I DO?
This will help you in your problem. 1. Turn on your pc 2. Installed the Mouse Driver on your system pc. (NOTE! if it has a CD or DVD Disk included on it ). (But if the product don't have a CD or DVD disk, you can proceed to the 3rd step.3. Plug the receiver to the USB port on your system unit.
4. Plug the battery to the mouse. (follow the instruction for the the battery. cause it contain + sign and - negative sign.
5. After doing the procedure from 1 to 4.
6. Restart your PC (cause some of the system unit need to be restart the system in order to recognize the fresh hardware plug on it).
7. Your Done
Good luck and i hope this steps will help you in your problem God bless.
Apr 07, 2010 | NexxTech NWOMMI Mouse
My logitech mouse has a blinking orange light one it
had a similar problem. i took the new batteries out again and WAITED about 20 seconds before putting them back in. the red light stopped blinking.
Jul 21, 2008 | Logitech MX 600 097855036162
MS wireless notebook mouse 3000 not working?
A friend of mine brought me this problem with exactly the same problem. here is what I found. The small notch in usb device socket under the mouse was malfunctioning. If you press this notch you will find the mouse red light blink. If you further try pressing this notch at some point the mouse red light comes on constantly. Thats it, hold it there and try to connect first by pressing the usb device connect switch and then the mouse connect switch. The moment the connection is made the usb device stops blinking and the red light on the mouse starts blinking. Wow, it works now. Some one might just open the mouse and fix this microswtich for a permanent solution.
Jul 08, 2008 | Microsoft Wireless Notebook Optical Mouse...
Computers & Internet Logo
87 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
