Question about Ricoh Aficio GX5050 GelSprinter InkJet
Getting Fax Reports from RICOH Aficio 2020D
We are wondering if we are getting all of our faxes from our machine, and can not figure out how to get fax reports printed off of our machine. How would we do this?
  • 537 Answers
SOURCE: fax transmission reports
What you are explaining should work. If you need prior activity reports from previous faxes, you can press Function then 2 (Act. Report)
I think you might need to press Function, then 7 then 1
From the manual:
Transmission Verification (Xmit) Report You can use the Xmit Report as proof that you sent a fax. This report lists
the time and date of transmission, and whether the transmission was successful.
When the feature is OFF, the report is printed automatically only if an error occurred during transmission. If the report indicates NG, send the document again. If the report indicates you should check the readability of certain pages, resend those pages.
If you typically send multiple faxes to the same destinations, you may need a reminder to identify each fax transmission. You can select OFF+IMAGE or ON+IMAGE to print a portion of the first page of the fax message on the report.
1 For the FAX, press Function , 7 , 1 .
For the MFC, press Function , 1 , 7 , 1 .
2 Press or to select OFF, OFF+IMAGE, ON or ON+IMAGE and press Set .
3 Press Stop to exit.
Hope this helps you.
Posted on Nov 14, 2007
  • 86 Answers
SOURCE: Discontinue fax transmission report
  • User Tools/Counter button
  • Facsimile Features
  • Key Operator Tools
  • Parameter setting
  • Select Switch No. 03
  • Select Bit No. 5 for Immediate Transmission and
  • Select Bit No. 0 for Memory Transmission
When the Bit number is pressed, the current value switches between 1 and 0.
Please set these two Bits to 0 to disable printing of transmission result report.
Then press;
  • OK
  • Exit
  • User Tools/counter button
Good luck and please rate me, thanks.
Posted on Jan 29, 2009
SOURCE: Won't receive all pages of a fax. Generating service codes 00-83
That could be caused by a number of things:
Are you connected to the phone line by a very long telephone cable? This can cause extra interference and cause these codes. Or it could be a deteriorated cable...try another one.
otherwise, it could be a fax circuit board problem, but more likely you need to have the 'cable equalizer " adjustment performed in "service mode", which is a fairly simple adjustment for a service tech, but too complicated to explain here.
I hope this helps.
Posted on Apr 13, 2009
  • 566 Answers
SOURCE: How do I delete stored faxed numbers (speed keys)
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
Posted on Jul 29, 2009
  • 903 Answers
SOURCE: Fax Result E-3) 3)
On the report where it shows the E-3 error, it should have a legend further down the page that shows what each error means. I think E-3 is "line busy," but check that legend to be sure.
Posted on Jun 05, 2010
I have ricoh aficio 1018d can it fax or print and i cannot find connection points on machine
You can fax or print with the aficio 1018d provided that you have the fax and printer options. these connection points are located at the back of the machine.
Mar 06, 2010 | Ricoh Aficio 1018D Copier
How do I turn off the fax notification on a Ricoh Afico MP 3500
Most Ricoh multifunction printers have a set of parameter lists that control reports and journals. The parameters are set by using bit switches in the User Tools, and each machine has different switches to control different settings.
What kind of fax machine or printer do you have? The user manual has a list of all parameters and bit switches.
Jan 21, 2010 | Ricoh Aficio CL2000N Laser Printer
RIcoh Aficio 2045,turn off fax delivery report
download the manual from the web site for the fax advanced features.
Refer to page50, from the pdf numbering.
Or at page147, from the document it self numbering.
Here is a link for quick find:
Jan 21, 2010 | Office Equipment & Supplies
Ive recently purchased a RICOH Aficio Super 180 G3...used.
press the "user tools" botton, then select "fax option",than "program fax information".You can change fax header there. "Time and Date" usually in "System" submenu.
Sep 10, 2009 | Ricoh Office Equipment & Supplies
Need to Double Side
press the "duplex" button on the operation panel
Jul 23, 2009 | Ricoh Aficio 1515F Plain Paper Laser Fax
Trying to change a fax number in memory
To change info:
"user tools" (ok)
"fax features" (ok)
"general settings /Adjust" (ok)
"program fax info" (ok)
...then set name, number, etc.
"user tools" to exit
To print speed dials:
"user tools " (ok)
"fax features" (ok)
"reports / lists" (ok)
"dial list" (ok)
"Quick dial list" or "speed dial list", etc (ok)
I hope I'm your Hero now :)
Please rate me.
Apr 01, 2009 | Ricoh Aficio 1013F Copier
History of fax reports
Press job information key
Select Print Journal by using the up and down arrow keys and then press ok
Press the "green" start key
the machine remembers the last 50 communications
Oct 07, 2008 | Ricoh Aficio MP1600SPF Copier
Ricoh aficio error message 06-06 page not received
its a fax error that states there is a line problem, problem is probably static in the phone line
Feb 18, 2008 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh Aficio GX5050 GelSprinter InkJet Logo
177 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
