Question about Acer 22" X223w LCD Monitor
I have LG1730 lcd monitor. I reinstalled my machine recently. since then i was having sometimes that the LG was not turning on while the PC was powering. now, I replaced my power supply with a new good quality one. My LG is not responding at all now. I tested with my laptop, same results. seems dead. If there any hard reset that can be done on it, before I will need to but a new one? it's only 2 years old.
  • Anonymous Jan 14, 2009
    Just FYI,
    Eventually I needed to replace the monitor. It worked after I changed the power cable, but after one hour it was back.
    It was a tricky one, because it did not behaved in a consisted way.
    The problem was related to the power on the monitor itself and fixing it was more expensive the buying new one.
    So, in case you have similar issue, get ready to change the monitor..
    Genius:
  • 1,913 Answers
Change your power cable then try.if it gived power led then your lcd is ok.
then let me know.
Posted on Jan 09, 2009
My lg lcd 22' flatron just turn green,i can still use it but i had to get use to its green display, what should i do to make it back to normal??? pls. help....
Have you tried taking out the connecting VGA cable and putting it back in? (Sounds silly but sometimes works!) Also, can you try using a different cable to see if it is a cable fault? Try the monitor on a different PC/laptop and then you can tell if it is a fault with the PC or the screen.
Jul 26, 2011 | LG 22" FLATRON LCD Monitor
When I turn off the computer or restart the computer or put it in a sleep mode, my LCD monitor LG Flatron W2234S always turns black but the LED stays blue instead of yellow and the monitor does not react...
Try changing the Resolution for the lowest one, if it works it will see the letters and everything very big. I have same trouble, specially since I change the original Vista Starter for the new Windows 7, I have not found a free controler that helps me and I have seen many people with same the problem. Sorry for my english.
Dec 11, 2010 | LG 22" FLATRON LCD Monitor
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
LG W1952T LCD monitor power save mode during bootup?
called customer service - see other post for details
May 11, 2009 | LG L1915S 19" LCD Monitor
PC running without anything showing on monitor.
Hi
Sounds like you have somehow deleted the driver for the monitor - - you need to plug another monitor into your PC - you can use the laptop you are using now - then you need to download the driver for the monitor again when you can see on the screen
May 03, 2009 | E-Machines eMachines Desktop PC
Strange Display Issue
Although it could be a monitor problem, try deleting it from the Device Manager list under Monitor.
Then reboot your PC and if you are lucky, Windows will find it and reinstall the necessary driver.
Considering that it is an LCD, there aren't many ways it can cause that kind of display.
Aug 26, 2008 | LG Studioworks 570LS 15.1" LCD Monitor
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 26, 2008 | LG Flatron L1710S 17" LCD Monitor
When the PC starts the monitor does not come out of the power standby mode
Hi The problem is to do with a 680uf capacitor that tends to bulge and fails.this stops the monitor staying on when trigerd to do so,change this and happy day.
Jan 16, 2007 | LG Flatron L1715S 17" LCD Monitor
Acer 22" X223w LCD Monitor Logo
81 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
