Take out ur harddrive, turn ps3 on wit no hardrive den put it back in and turn on again,
if this dosent work hold power button and eject button on front of ps3, 1st u will hear 1 beep then 2beeps ,wen u hear 2 leave go,
it will say connect controller with usb, do that and u will get 6 options,
pick option 3,but if that dosnt work pick option 6 ,but option 6 will delete all ur saved data so be warned.
Solution:
SAFE MODE:
1.
Place you
finger on the on/off sensor leave it their until you console turns off then
take you finger off the sensor.
2.
Place your finger back on the on/off sensor
leave it their until you hear 2 consecutive beeps then take your finger off.
3.
Once the safe mode screen comes on select the
option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all
data except the OS. I recommend backing
up your console onto a USB flash drive if possible.
Good Luck!
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
