Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Green light comes on then off 3 times.
The power button light comes on then off and cycles 3 times. The T.V. does not come on. you have to do this several times and hope the T.V. comes on. Is this a starter relay that has gone bad?
    Problem Solver:
  • 8 Answers
I had this problem with mine. And it is caused because it is a safety shutdown-
The Safety shutdown may be broken into five distinct sections:
• Audio Power Supply and Audio Output Monitoring
• Main Run Power Supply Loss (PS LOSS)
• Rear Projection Instrument Safety (CRT Scan Loss protection)
• Startup Delay
• Power Supply Overvoltage
When taking measurement I used Pin2 of IP250, It is located in G-0 on the Voltage regulator board.
First off, check the main safety transistor, TP210 located at G-2 on the power supply/scan Bord. It will have 3 semi large heat sinks and the main tube power cables coming off of it.
The Emitter should always be 5Vs, The emitter is also the Furthers pin form the heat sink it is right by, So if looking at it face on to the flat side of the transistor the emitter is on the right.
The base when in:
normal high
protect low
off low
The collector goes to the power switch and should be
normal low
protect high
I pulled mine out to check to see if it was bad because it was reading odd like a shored EC, and it checked out fine. After re-soldering it back in, my set worked fine! Over my TV's life it seemed to have produced a weak point in its solder joint I guess. That in your case seems like it is about to go out for good.
I would say just re-solder that and you should be good to go!!
It this does not work for you let me know, I have much more information.
Regards
Joe
Posted on Jan 10, 2009
5 yr old tv goes through cycle and tries to come on, eventually does but after many tries.
My sony did almost the exact same thing. I removed the bulb & cleaned all the dust out of the cooling ducts & the screen on the bulb was full of dust. That bought me about a month, then I replaced the bulb & haven't had a problem since(over a year ago). Just make sure you NEVER touch the glass of the new bulb with your hands,oil on your skin will greatly shorten the bulb life! I found a bulb at a local electronics store for under $200.00... don"t forget to clean dust from cooling ducts,& make sure cooling fan is working, bulb gets extremely hot!
Mar 02, 2012 | Televison & Video
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
TV turns on then off no picture
this is very common. it is the power supply going bad. it should run at 130 volts dc. but it is now running much lower that this. just enought for the tv to come on. but not enough to power all the circuits right.
Nov 20, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52--Delayed Power On and does NOT turn on now.
U DM power supply board have dead capacitors,before the capacitors have some functions left,that why u able to recycles by pushing the power buttons 3 or 4 cycles to get power to the tv.U have tools,soldering iron,solders,and know to do soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,that design to replaced in the DM power supply board.Look around and replaced these dead capacitors,it alway bulges up or puff up on it top.Ur tv will power up and as normal again.
May 30, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52inch HDTV (2004 model) green power light flashes 3 times
Replace the flyback 259296 and the cp150 You can get the aprts with detailed instruction on how to do the repair at the following link.
http://servicemanuals.vstore.ca/
Jun 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power button malfunction
Sounds like a faulty power supply. Consult warranty guide if its still under warranty, if not, you really need to consider calling a repair technician
Feb 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
GE 52" will not power up - green light flashes 3 times
Replace CP150 and CP114 and CP120/ You can get the caps with instructions at the following link. They do have a minimum order amount of 10.00 so you may need to order an extra capacitor to total 10.00 but shipping is free. The parts are listed under the RCA parts category,
Feb 07, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Red/Green Light Problem
Had same problem after only 3 months, tech looked at it said had a power circuit problem causing it to keep cycling, they exchanged my TV. No problem since.
Oct 29, 2007 | Toshiba 46HM95 46" HDTV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
56 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
