Question about Sony Playstation 3 (PS3) Console
40G PS3 system corrupted
"The hard disks file system is corruped and will be restored"
"x to enter repair" "ps button to begin use"
The Ps button will not work, it comes up with a stop sign
once the repair finished it immidiately restarts and comes up with the same message menu.
I have tried this in reference to the manual "safty and support" that does not support this problem
please help
  • amoxom Apr 02, 2009
    I have the same problem. My drive was corrupted. I reformatted it with Swissknife software as a FAT32 volume on my PC using a SATA external drive housing. I put it back into the PS3 tried it again and went through the process of downloading 2.60 code to a USB storage device. I followed the console instructions of pressing select and start at the same time. THE PS3 console takes that USB data loads it and says its successful, retstarts the system and it does not boot up!
  • Stephen Munn
    Stephen Munn May 11, 2010
    You can reformat your drive by removing it from the PS3 (these are modular) and putting it an external HDD case, then connecting that to a computer. You can format using the computer, then remove it and put it back in the PS3. You'll lose everything, but you'll get your PS3 back up and running. Sorry there isn't an easier solution.
    Be aware that if this happened after you turned off your PS3 while it was writing to the hard drive, that is one thing that can cause this.
  • 344 Answers
Hello. If the hard drive will not reformat inside the PS3 when you press X, then you will need to remove it and reformat it on a PC using an external device or replace the hard drive. Thanks.
Posted on Jan 09, 2009
Ps3 says hard disk's file is corrupted and will be restored starts restoring then goes back to screen saying hard disk's file is corrupted.what can i do now?
follow this procedures its a solution to corrupted hard disk.
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Good luck.
Jul 29, 2010 | Sony Playstation 3 (PS3) Console
Tip
Sony PS3 Hard Drive Corrupted or Asking for Restore
A Hard Drive error can be a common problem on the PS3 and this tip will outline how you can troubleshoot and hopefully resolve a hard drive problem. If your PS3 is showing signs that the hard drive is corrupted or is displaying a message asking you to restore the hard drive follow these steps carefully and you may well avoid an expensive repair or having to consign your hard drive to the bin.
Please note: Steps 8 and 9 involve erasing data from your Hard Drive. Therefore if at all possible please try to back up your data before commencing this procedure. You can do this through 'System Settings - Backup Utility' Follow the instructions given in this menu to back up information to an external storage device such as a USB Pen.
To begin the process of troubleshooting and resolving your Hard Drive error you must first put the unit into Safe Mode. Follow these steps carefully;
1) Turn off the PS3 by holding the power button on the front of the unit till it turns red.
2) Hold the power button until you hear the unit beep three times. This will take 15 to 20 seconds.
3) The unit will power off on the third beep and power light will turn red again.
4) Touch and hold the power button again as in step 2. The unit will beep three times except this time the third beep will sound like a quick double beep. As soon as you hear this release the power button.
5) You will see a message onscreen telling you to "Connect a controller using USB and then press the PS button".
6) Do as the message says i.e. connect the controller and press the PS button - you are now in Safe Mode.
7) Restore File System. From this point select "Restore File System" on the menu. The PS3 will attempt to repair damaged files on the hard drive. If this does not work move to step 8.
8) Rebuild Database. Enter Safe mode again as outlined and this time select "Rebuild Database". Be aware this mode will erase certain information from your hard drive which is not recoverable such as photo and message information. If this fails move to step 9.
9) Restore PS3 System. Again enter Safe Mode and select "Restore PS3 System". This will restore all defaults and completely formats the drive. Be aware this mode will erase all information from the hard drive.
If everyone of these steps fail and the PS3 is still showing symptoms of hard drive error you can be certain that the hard drive has failed and it will need to be replaced. However in a majority of cases these steps will resolve the issue.
on Mar 04, 2010 | Video Game Consoles & Games
I was downloading update for PS3 and now the playstation says "The hard disks file system is corrupted and will be restored." when I click ok it counts to 100% like it's restoring it and then it restarts...
I wish you good luck.
Mar 18, 2010 | Sony Playstation 3 (PS3) Console
Hi my hard disk's file system is corruped how can i fix it?
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
Connect controller to PS3 screen.You will then see a screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. Connect controller to PS3 screen.You will then see this screen. Safe Mode options screen
You will then see this screen. "The hard disk's file system is corrupt and will be restored."
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
The hard disk file system is corrupted how do i
johnnolan1
If you are getting the corrupted hard drive message this means that you have corrupted data on your hard drive. The link below will help you address this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
My PS3's hard disk file system is corrupted
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
Hard disk file system is corrupt
I had same problem, I made Circuit City exchange mine out. I could not figure out how to fix this problem. if its under a year old call Sony and have them fix for free. They will send you a box with pre paid postage, and fix for free.
Dec 20, 2008 | Sony Playstation 3 (PS3) Console
My ps3 tells me the hard disk is corrupted
Sounds like you might need a new hard drive. You could try to disconnect it and reconnecting it, but usually it does not fix the problem. just remember you need a 2.5 sata hard drive (might be a good thing, if you ever wanted more hard drive space).
Dec 13, 2008 | Sony Playstation 3 (PS3) Console
PS3 startup problem
replace the hard drive, it's probably corrupted.
Dec 28, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
118 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
