Question about Bunn NHB Coffee Maker
Water leaks out of holes up under resevoir.
When coffee is brewing water streams out from under both sides of resevoir
  • Anonymous Mar 27, 2014
    when waiting for coffee to brew, hot water is being pumped back into water resevoir.
    Problem Solver:
  • 5 Answers
Use a Torx T-9 tamper resistant screwdriver to remove the screws on the bottom of the coffee maker.
Your plastic tube has probably come loose or is leaking. Carefully re seat the plastic tube over the metal tube using the metal spring compression clamp.
Posted on Jan 09, 2009
It leaks water under the right side of the brew basket.
Leaks water when brewing ground coffee with a My K-Cup ...
https://www.ifixit.com/.../Leaks+water+when+brewing+ground+cof...
iFixitWhen I use the My K-Cup filter to add my own ground coffee and brew it, after it ... the machine starts leaking water at the same time, so typically the mug beneath the ... in the lid that has the needle opening in it (half sphere perforated basket below it). ... thewater could simply flow over the coffee, and go right down the sides.
Stop Leaks - www.My-Cap.com © 2015
www.my-cap.com/stop-leaks.html
Jan 01, 2016 | Coffee Makers & Espresso Machines
Leaking water out of bottom and will not brew a full cup
It may be time to descale. Most models will give you a message when it's time to have the mineral deposits cleaned.
HERES HOW TO DO THAT...
Empty water resevoir. Disable auto off. Pour approx 48 oz of undiluted white vinegar into resevoir. PLace large mug on drip plate, run brew cycle, dump contents of mug in sink. DO NOT USE A K-CUP.
Repeat this process until the add water light is indicated.
Let brewer stand for at least 4 hours while still on.
Discard any residual vinegar in the resevoir and rinse thorughly.
AFTER approx 4 hours...fill resevoir with water.
RINSE:
PLace a large mug on the drip plate and water brew cycle. Pour the contents of the mug into the sink.
REPEAT this brew process until the add water light is indicated.
YOU MAY NEED TO REPEAT THIS "RINSE" PROCESS if you notice any residual taste.
Apr 14, 2013 | Keurig Platinum B70 Coffee Maker
How to fix the leak from the bottom of my cuisinart dgb-900bc
Re: Cuisinart grind and brew model DGB900BC leaking from the bottom. Finally fixed it before buying a new one. Remove the 4 torq screws (#10 bit check auto stores) from the bottom and remove the bottom. You will see a horse shoe shaped metal coil that heats the water from the resevoir. I found that the coil had a small hole in it. Cleaned it well and applied a coat of epoxy paste to the leaking area ( I used a product called PC11 from Ace) So far, no leaks, and the coffee maker is working like new.
Aug 10, 2012 | Cuisinart Dgb-900BC Grind & Brew Thermal...
Machine leaking water from service door behind where the pucks collect. water pools/collects into the excess ground coffee tray. any suggestions?
Hi
Trying to understand what you are talking about, but if you have water in the top left side of the brew unit, its your thumb screw. If you have water under the brew unit Its the drain for the pressure release. remove the brew unit. The injector behind the brew unit on the machine has a drain and it can get clogged with coffee residue. If there is water below the injsctor the drain hole is inside and towards the front of the machine. A long zip tie inserted in the drain aimed down towards the front will usually find the drain hole and clear it, then take some hot sudsy water and flush the drain.
If its the thumb screw you will ahve to get a new one but be sure to remove the extra nut on the filter screen shaft before installing the new one.
Jan 01, 2011 | Saeco Magic De Luxe Espresso Machine
Very little water comes out while brewing and its brand new
Could be the exit valve on the k-cup holder is clogged.had same prob and fixed in 2 mins.Take out k-cup holder as if you were going to brew your own grinds.It will twist off into two pcs.Take the top pce and get a paper clip and stick end of paper clip into valve from the bottom and wiggle a little then run under water to clean out.reassemble and you should be brewing coffee again.Good luck
Apr 07, 2010 | Keurig Platinum B70 Coffee Maker
My 10 cup Bunn coffee maker leaks from the top of the water resevoir, from the right top side and from the back top. It looses aprox. 2 cups of water onto my counter while brewing. What has happened to...
I have the same problem and I took the coffee maker apart to find out why. It has to do with a leak on a fitting. On mine I found that the fitting where the hole in the black plastic that the water flows through to get into the stainless steel tank needed to be repaired with some silicone sealant to fix the leak. Still making some coffee!
Oct 09, 2009 | Bunn 10 Cup Home Coffee Brewer
Leaks water when brewing from right side where
It is possible that the small gasket under the water pan is damaged and needs to be replaced.
Jun 16, 2009 | Bunn VPR Coffee Maker
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Bloomfield Koffee King coffee maker
TRY REPLACING THE SEALS IT WORKED FOR ME
May 22, 2007 | Bloomfield 8571 Coffee Maker
Bunn NHB Coffee Maker Logo
396 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
evans_lloyd
Level 1 Expert
gbob59
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
