Question about EliteGroup K7S5A Pro Motherboard
Hey Ya'll i have your motherboard K7S5A an i can get it to start up however when it loads it tells me hdd error hdd slave error but im not sure i have the wires for the hdd and power wires in the right spot on the board itself can you plz tell me where they go or send me a wiring diagram to my email or if you can think of any other reason as to why its doing that i would be much abliged.
  • bigscorefour Jan 10, 2009
    that didnt work is there anyone who has a wiring diagram for this motherboard would be greatly helpfull i cant get the darn wires right lol. would be much abliged if some one had a wiring diagram.
    President:
  • 1,179 Answers
Either the wires are not properly hooked up but more likely would be that you have the jumpers on the back of the hdd's improperly set. Hope this helps.
Posted on Jan 09, 2009
  • Roy Lonsinger
    Roy Lonsinger Jan 10, 2009
    Should be a ide ribbon cable that daisy chains the two drives. On your motherboard in small print it will say ide controller. This is where one end plugs into the board. The other 2 ends go one to each hdd. Then there should be a 4 pin molex from the psu to each hdd. Hope this helps as I could not find an actual wiring diagram for this board.
  • Roy Lonsinger
    If you are using SATA then they should be color coded on the board. Red is usually primary hdd & blue is secondary. The power cables for sata come from the psu & plug into the SATA power port on the back of the hdd. It will be labled on the back of the hdd as data & power. Hope this helps.
How can I use a SATA HDD in a 7NF-RZ motherboard? What cables/adapters are required?
Hey there. To install SATA devices on any motherboard follow these steps:
1- Make sure your Motherboard supports SATA, a 7NF-RZ works fine.
2- Install the HDD on your case, usually you have to screw it in or if you have a newer case you can lock it in place with a latch.(The SATA slots on a case are usually above the optical drive slots).
3-If you have another HDD already installed, and you don't want the new HDD to have system files, make sure it's designation is set to Slave. To do this, remove the jumper on the HDD pins(a white plastic connector) with tweezers, and, according to your HDD specifications, move it up or down to Slave designation.
4-Use a SATA cable from your Power Supply and connect it to the HDD, then, use a SATA adaptor cable which should have come with your HDD and connect it to the HDD, then to your Motherboard SATA adaptor(these vary from motherboard to another, so use your Manual to specify where it is).
5-Boot up your computer, and enter BIOS. Usually press either F2,F5,F12 or Esc. After that go to Auto-Detect drivers. When you're done, Save & Exit.
You should have successfully installed your new HDD!
Aug 21, 2011 | Gigabyte 7NF-RZ (GA-7NF-RZ) Motherboard
On the k7s5a motherboard i am getting an error stating acpi not supported by the bios
Hi s_gehring,
Have you installed something new on your board? What this is telling you is that the ACPI (Advanced Configuration and Power Interface) does not work with something on the board. Or check your bios setting and make sure you have ACPI turned on.
Thanks Mark
Nov 21, 2009 | EliteGroup K7S6A Motherboard
Start up error message issue: floppy disk fail
if im correct, you havent installed a floppy drive yet...
while the comp is booting press esc (on some comps its F10 it should say on the screen) and access the boot sequence..in there there is a list of boot items...they always list floppy drive as the first boot drive in case you need to recover your comp...remove floppy drive from your boot list making sure that your hardrive (C) is first drive to boot.
After you get your comp set up, you may want to change that sequence in case you ever have problems with your HDD
add a comment if you need more help
Jun 22, 2009 | EliteGroup K7S5A Pro Motherboard
Only one drive showing out of two
Hi the cable ribbon is color coded. the blue should be connected to motherboard and the gray is a slave and the black is master. Check if you have this connected properly. If you got a Cable ribbon not color coded. The cable ribbon from motherboard connector about a 12 inches long from middle slave connector and 6 inches to the master connector. If this is not connected properly and HDD is not assign slave and master most likely the OS can not detect the HDD. The other way to check is to access your bios setup if the slave and master HDD is detect. Your PC have a capability of plug and play if you connect the hardware right and load the driver. Hope this info will help you to solve the problem.
HH
Apr 20, 2009 | ASUS (M2NGREEN) Motherboard
I am working on my friends k7s5a Pro Mobo...
If you wish, tell us the socket number and we can then look up your board specifications. My guess is that the board runs pc2700 chips as the max speed possible.pc 3200 is faster(400MHZ)    than pc2700(333MHZ).
Mar 19, 2009 | EliteGroup K7S5A Pro Motherboard
CDBOOT: memory overflow error.
Hey there,
At first you need to tell me whether ur hard drive is sata or pata.
If u r having Sata drive then this error occurs due to absence of SCSI Controller driver.
Else if u r using PATA Drive then Try change the bios ssetting.
Go to advanced --> Sata Configuration --> and then disable SATA native mode.
Try out above mentioned solution it'll surely help you.
Thanx.
Gimme your acknowladge by rating my solution.
Romy
Dec 24, 2008 | Intel Desktop Board D845GERG2 Motherboard
MATSONIC MS8157E MAINBOARD
Check the jumpers on the drive, should either be master/slave or all cable select.
Aug 12, 2008 | Matsonic MS8147C+ (N82E16813184008)...
K7s5a sound driver
Hi, Code 10 refers to device not starting which can mean either hardware failure, corrupt drivers or wrong driver. The K7S5A uses either an SiS 7012_111 or an CMedia AC97 depends on the audio chipset installed in your motherboard version. Google for the necessary drivers and try which ever will work. Good luck and kind regards.
Sep 28, 2007 | Computers & Internet
EliteGroup K7S5A Pro Motherboard Logo
184 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
