Question about HP Pavilion 7965 PC Desktop
My hp 7965 pc desktop (pavillion) starts fine but when loading windows xp, it gets to a piont and restarts the computer completely, over and over again. HELP please!!
    Prodigy:
    An expert who has answered 500 questions.
  • 674 Answers
Following are the steps that shall be followed in case ones computer is slow to start up:
  • Block the start-ups and services
  • Defragment the disks
  • Defragment your registry
  • Set up the system for best performance
  • Disinfect the system
Block the Startups and Services
When your computer is started up, there might be a number of programs and services running in the background. Some of them would be update checkers, error reporters and the rest are necessary tools like your antivirus etc.
The idea is to disable running the start-ups and service that you no longer need.
  1. Click Start ' Run.
  2. Type MsConfig and press ENTER.
  3. Disable the start-ups and services from the Startup and Services tabs respectively.
  4. Click OK button and restart the machine.
Defragment the Disks
My computer is slow to start up if the disks are too fragmented. Fragmentation refers to dividing a file into several parts which cause slow down in retrieving their contents.
The problem can be solved by defragmenting such fragmented disks using the Disk Defragmenter.
  1. Click Start ' All Programs ' Accessories ' System Tools ' Disk Defragmenter.
  2. Select all the drives.
  3. Click Defragment disks button.
Defragment your Registry
Registry is the database in your operating system containing significant configurations and information. Registry fragmentation too cause my computer is slow to start up issue.
Defragmenting the registry is too simple. You have to download a third party Registry Defragmenter software and install it o your system.
Set Up the System for Best Performance
Setting Windows for maximum performance rather than best appearance could fix the problem. Whenever my computer is slow to start up I perform the same task. The steps are provided below:
  1. Right click My Computer.
  2. Select Properties.
  3. Click Advanced System Settings link at the left hand side of the window.
  4. Click Advanced tab.
  5. In Performance frame, click Settings button.
  6. Select the option Adjust for best performance and click OK ' OK.
Disinfect the System
Sometimes computer is infected by a virus and I feel that my computer is slow to start up.. Change the existing antivirus software and download a good one. Update its virus definitions and conduct a full scan through it. Remove all the infected files that found.
Fix My Computer is Slow to Start Up Now
Posted on Jul 08, 2011
    Scholar:
    New Friend:
  • 42 Answers
Some Software Applications May Cause Windows Stop Responding or Restart During Startup or Boot in Windows XP.
If a PC that has been working properly fails to startup or boot, especially after a new application or driver is installed, it is necessary to perform one or more of the following methods to correct the problem. The PC may lockup, freeze, hang, or automatically restart when the Windows Desktop first displays during startup.
Method 1: Disabling automatic restart
This method disables automatic restart if you are unable to view Windows Desktop and/or the notebook continues rebooting automatically (whether by the user or the notebook continues booting without user intervention).
1. During the rebooting process, repeatedly press the F8 key to enter Windows Advance Options Menu.
2. Use the up and down arrow keys to select Disable automatic restart on system failure and then press the Enter key.
3. Use up and down arrow keys to select the operating system to start (if more than one OS is installed).
4. Press the Enter key. Windows should start.
Method 2: Use last known good configuration
Using the last known good configuration may allow the pc to boot to Windows using the most recent settings that worked.
2. Use the up and down arrow keys to select Last Known Good Configuration (your most recent settings that worked) and then press the Enter key.
4.Press the Enter key.
Method 3: Use System Restore to reset Windows to an earlier known safe operating point
This method reverses recent operating system changes to the notebook PC, such as the installation of new software, and takes the computer back to a previous working state. This method may uninstall or remove the software that is causing the problem. Check with the software manufacturer for any known problems and reinstall the software if appropriate.
1. Start Windows in the Safe Mode as follows:
- Remove any disks or CDs, and disconnect any external devices or peripherals.
- Press and hold the Power button for 5 seconds to turn off the computer.
- Press the Power button to turn on the computer.
- Press the F8 key repeatedly when the first screen appears.
- From the Windows Advanced Start-up menu, select Safe Mode and press ENTER .
The computer may run slower in the Safe Mode and the desktop will not look as nice due to reduced colors.
2. Click Start , then click Help and Support .
3. On the Help and Support home page, click System Restore .
4. On the System Restore page, select the Restore my computer to an earlier time option and click Next .
5. Navigate through the calendar looking for a highlighted date and select a restore point date and time that is earlier than when you started experiencing the problem, then click Next .
The computer should shut down and turn back on by itself after the restoration completes. When the Restoration Complete window appears, click OK to continue.
Method 4: Uninstall recently installed applications using Add/Remove Programs
- Press and hold the Power button for 15 seconds to turn off the computer.
- From the Windows Start-up menu, select Safe Mode and press ENTER .
The computer may run slower in Safe Mode and the desktop will not look as nice due to reduced colors.
2. On the Windows taskbar click Start , click Control Panel and then click Add or Remove Programs .
3. Navigate through the alphabetical list of all installed programs and select the name of the most recently installed program or programs.
4. Click Remove , click OK when prompted to verify the removal of the program.
5. Restart the computer by selecting Start , Shutdown , and Restart .
- If the computer starts up properly, contact the software manufacturer for updated instructions for a proper installation.
- If the computer does not start up properly, reboot the computer in the Safe Mode and repeat the methods for uninstalling any other recently installed software.
Method 5: Remove applications that load during startup using the System Configuration Utility
If the system fails to start properly after installing a new software application, there may be conflicts with the application if it loads during startup. To resolve the problem, it may be necessary to use the System Configuration Utility to remove the application from Windows startup, or to change the startup sequence.
- From the Windows Start-up menu, select Safe Mode and click ENTER .
2. Click Start , click Run , type MSCONFIG , then click OK .
3. On the System Configuration Utility window, on the General tab, select Selective Startup option, and unselect the Load Startup Items .
4. Click OK and then click Restart .
The computer should restart and operate properly even without loading any of the startup items. Most startup items are helpful utilities that run in the background or sit in the system tray until they are needed.
- If the computer does not restart and operate properly, there is a more severe problem and performing the method for reinstalling the Windows OS may be necessary.
- If the computer restarts properly, examine and enable the entries under the startup tab.
Posted on Jan 09, 2009
How do you put the computer in safe mode on a HP pavillion?
If I remember correctly, for Windows XP:
Click on 'Start' at the bottom left of your screen
Click on 'Run' - should be on the right side of the Start menu towards the bottom.
A box will appear at the bottom of the 'Start' menu. Enter "msconfig" (without quotation marks), and press the Return/Enter Key.
A new window will open with several tabs. Click on the BOOT.INI tab to open that, and click in the square box first on list by /SAFEBOOT. There are three variants of safe mode. For now, choose 'Minimal' (click in the circle by that word). Now move to bottom right of the MSCONFIG window and click on the 'OK' button. Now the window will close, but next time you Restart/Start your computer it will be in Safe Mode (font will different, and it will say 'Safe Mode' at the four corners of the screen).
12.April.2014
Aug 30, 2012 | HP Pavillion s7420n PC Desktop
I purchased a QVS brand USB, type A to B, high speed cable to connect my Dell 944 Photo printer to my HP Pavillion 7965 PC. I cannot find a receptable piece on the back of the PC to accommodate it. Do this...
it should not require an adapter the bigger usb portion goes into the printer and the smaller will fit into your usb on your computer back ports. if the ports are to big you bought a mini usb adapter on accident. let me know if this helps.
Mar 13, 2011 | HP Pavilion 7965 PC Desktop
Hello. Re: HP Pavillion 7965 Where is the power switch located on the system unit?
Hi.
The on off switch is located in the front side, right below the drives.
Most HP PCs do not have PSU power switch at the back.
Regards.
Ginko.
Nov 03, 2010 | HP Pavilion 7965 PC Desktop
MS Vista Windows patches broke my desktop
reboot the computer and then press f10 this should get you a screen with a text line that says safe mode,with net or command scroll down to last settings that worked and try that ps. you really need to make a recovery disk. its that important.
Jun 29, 2009 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
Start system recovery
Put disk 1 and restart Windows. When it restarts, it'll start recovery. At some point it'll ask you to switch to Disk 2.
Mar 20, 2009 | HP Pavilion 7965 PC Desktop
Failure to load windows?
Turn on the computer.
Press F8 every few seconds.
You should get a screen with a ton of choices.
Choose Safe Mode with Command Prompt.
Write me back when you're this far.
Feb 26, 2009 | HP PAVILLION DV6841TX PC Desktop
Computer tower started beeping
If you added more memory this may make your tower beep.
If so I WOULD REMOVE THE ADDED MEMORY AND THEN RESTART
Jan 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
How to restart hp pavillion 7965 desktop
Hi there. Try these steps:
1. On restart, press F8. This should bring you to a screen with various boot options.
2. Select "Last known good configuration". Windows then may load correctly.
3. If this doesn;t work, try the same thing. This time select "boot in Safe Mode". If Windows now loads in Safe Mode you should be able to restart and Windows may load correctly after this.
4. If these two both fail, you may have to repair Windows...
Jan 09, 2009 | HP Pavilion 7965 PC Desktop
HP Pavillion m7177a, no sound
just installed the motherboard cd of your hp pavillion
Dec 16, 2008 | HP Pavilion Media Center a1330n - AMD...
HP Pavilion 7965  PC Desktop Logo
212 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
