Squeaking when drying
What kind of vent piping are you using? The wrong vent pipe can cause the wheel over the heat element to overheat and squeak. It is recommended that rigid metal vent pipe is used now a days.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: squeaky dryer
Depends how technical you are. More than likely it is the rollers (depending on who made the Kenmore). Go to www.apwagner.com and you can get the parts there. Or if you are unsure about taking it all apart, call for service.
Sgt 48
SOURCE: irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
SOURCE: Kenmore 80 series dryer makes a constant squeaking
could be rollers, idler, belt or motor, we have to tear it apart and manually move things to find out... simply visit my site and call if you need help whirlpoolpartssurplus.com mark
SOURCE: Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
SOURCE: kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
