Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Anyone know of a detailed parts and assembly book for the Cabrio?
ALowes tech guy came out and determined our lovely Cabrio had rust. We had to move and had to put it in storage for 4 months. So, it doesn't agitate. Man found that rust had built up do to non-use and froze the parts together. It is VERY Expensisve to have them fix it as RUST is NOT in the extended warranty.
So, my son and I want to try our hand at replacing parts and reassembling it
  • 5,911 Answers
You can use the following two websites for excellent exploded view parts inllustrations of your washer:
You can print this drawing for your convenience. Just use your washer model number for your search criteria. If you need avice, or assistance with anything please let me know.
Posted on Jan 09, 2009
The lid to my whirlpool cabrio top loading washing machine will not open completely???
Hello. How old is your washer? Is there rust around the bleach dispenser near the left side hinge? What probably has happened is the hinge assembly underneath the top cover has rusted from the contact with chlorine and or fumes. These washers are notorious for rusting at the hinges, especially near the bleach dispenser. The parts involved are:
left hinge arm--w10389421
right hinge arm--w10389240
left hinge spring assembly--w10358931
right hinge spring assembly--w10358932
top cover--w10391067--if this needs to be replaced, call for service--it's a solid hour to 90 minute job for an experienced tech! You have to transfer ALL THE PARTS to the new cover and it's INVOLVED--trust me! If there is rust around the bleach dispenser and underneath the top cover, you might check your serial number with Whirlpool to see if you can get a new top cover for free covered by a service bulletin dealing with rusting. To raise the top cover, remove the top screws from the hinges on the rear of the washer holding down the top cover. Then, remove the screw and metal plate protecting the wire harness and pressure hose and set it aside. Next, from the front, slide the top cover forward 1/2 inch and lift up. Have a friend assist you in holding up the top cover. You can now access the hinges mounted underneath, check for rust, and also see how the suspension rods are mounted(they are very easy to remove since there is a slot in each rod holder located at each corner at the side of the tub near the bottom. You would pull up on the tub, release the top of the rods first, then reach down and unsnap the plastic clips(2) in the center of each holder. Use a headlamp or flashlight to see. The rod will drop down and can be removed through the slot. Reverse the procedure to install.
Also, in case your suspension rods get worn out(the tub has a hobby horse "bouncy" movement), the part number for the set of 4 is w10368625. The proper way to check the rods is to place your hands on the right and left side of the tub ring(the plastic cover over the basket) and shove smartly down and release--the tub should grip going down and pull coming up--no springy movement--just like shock absorbers on a car. It should come up and settle. If it has any bounce at all, the rods are worn--symptoms will be increased out of balance errors or the washer might start banging during spin. I hope this helps you. If you are hesitant about performing any of the repairs above, please call for service!
Oct 03, 2015 | Whirlpool WTW8600YW 4.6 cu. ft. Cabrio...
We are trying to recalibrate the washer using the book and it won't work. Any suggestions as to why?
Contact Whirlpool Service. Try to unplug washer, wait a couple minutes, then see if that reset it...
Mar 28, 2015 | Whirlpool WTW5700XW Cabrio HE Washer
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Wondering what code F-- means on cabrio whirlpool topload mod. wtw66005w2 Thank You
Is there a number after the F code?
Thats ok heres what the code means: Whirlpool Cabrio Washer Fault Codes.
Means primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part.
Hope helps.
Aug 03, 2011 | Washing Machines
Our laundry smells moldy since we bought cabrio several months ago. We've done everything we know to fix problem ,, but are not happy with the service of this machine or smell of our clothes at all!!
have you tried the super cleaner that works to clean just about everything--- vinegar
I dont know for sure if it affects several washers of that model but i have been a appliance tech for 30 years and haven't been to service that problem ever, the cabrio is what i have in my home and love it,cleans well without any foul smells
Jul 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Anyone know how to clear/reset the address book PW? Previous IT person left without documenting PW. Is there a service mode that may be able to clear it? Willing to wipe out and reload
look online for the default address book password, often IT guys and techs dont ever change these, as there is little point. common ones, 1234 12345 0000 admin , a quick search online for "default password for ????" should provide this info. if this helps , please give some thumbs up. Cheers! An IT Guy / gurvy
Aug 26, 2010 | Office Equipment & Supplies
My 3 year old Cabrio washer is making a loud bead bearing sound when spinning, especially at high speed. I have a lot of mechanical experience, I need a diagram or better parts list then the factory...
I just replaced the outertub/driveshaft assembly on my cabrio washer a month ago. It is now whisper quiet on spin cycle again. Go to any parts list on the web and order the "Outer tub/driveshaft assembly". I got mine delivered to my front door for about $185 total. I got the directions on how to work on it from the web. It only took a couple of hours or so. If you need the part number or part store let me knw. Good Luck.
Jun 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 code with washer
Yes. I took off the hood, thinking that it was a connection shaken loose by the machine moving.
The part on my Kenmore Oasis Washer that is causing the F1 response (system failure) is: P/N 8576385 Rev B. The molded gray plastic case is embossed with the initials "FSB" and "made in China."
Hope this helps. Brett
Jul 07, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
163 people viewed this question
Dan Webster
Dan Webster
Sal De
