Question about Tandberg Data Lands Phones
I can hear him but he can't hear me.
The user is attempting to set up a VTC conference but he can't hear me. I can hear him.
  • 79 Answers
Please ensure you have not "muted" your mic. Also ensure you mic is properly plugged in to the station.
Posted on Jan 10, 2009
How do i change the answering machine message?
This is from the attendant user guide. Don't ask me what a Conference Bridge Extension is though.
To recording your greeting:
1. Set the Supervisor Password, if necessary.
2. Call a Conference Bridge extension.
3. When the Conference Bridge extension answers, dial the
Supervisor Password and #.
16
4. Press * to skip the setting verification mode.
5. Press # to change the system settings.
6. Skip the steps until the Customized Greeting option is played.
7. Follow the voice prompt and record a new Customized Greeting.
May 06, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
Check engine light on. AutoZone says P1110 is the problem. WHAT is THAT?
P1110 Intake Valve Timing Control Solenoid Error
From what I've read, the plunger within this solenoid gets stuck, causing this error. Some have had success with applying lube to this part, while others have had to replace it.
The VTC solenoid valve is part of the Valve Timing Control System. The purpose of the system is to achieve optimum valve timing, thus improving engine performance.
The system will vary the intake valve timing according to engine speed, and other inputs received from the coolant temperature and throttle position sensors. The ECM controls the position of the intake camshaft, by controlling the oil pressure to the intake camshaft pulley hub. When the ECM energizes the solenoid, oil pressure is supplied to the pulley hub, changing the position of the hub, thereby advancing the intake valve timing.
1 Remove the VTC valve from the vehicle.
2 Using a fused jumper wire, apply battery voltage to terminal 1, and ground to terminal 2.
3 If the valve is functioning correctly, the plunger shaft in the valve should be extended.
4 If the plunger is not extended, replace the VTC solenoid.
1 Disconnect the wiring harness connector from the VTC valve.
2 Using a suitable wrench, remove the VTC from the cylinder head.
To install:
1 Install the VTC in to the cylinder head, by first hand tightening, then using a wrench.
2 Plug the wire harness connector into the VTC valve.
Aug 18, 2011 | 1996 Nissan Sentra
The instruction manual has been misplaced and I am trying to set up a conference with dial in people
here is the companies direct link to the user manual:
if you have the SoundStation 2 with a display here is the link:
http://support.polycom.com/global/documents/support/user/products/voice/soundstation2_with_display_user_guide.pdf
Without display
http://support.polycom.com/global/documents/support/user/products/voice/soundstation2_without_display_user_guide.pdf
Aug 16, 2011 | Polycom SoundStation2 Audio Conference
Three party conference call
Once you receive your first call Press conference button. your first call will automaticaly be on hold. Press a line button to dial second number. Once call is connected Press conference button and you will have 3 way conference.
To add more PeoPle into conference Press conference button again and select a new line. Dial the number and Press conference button to connect everyone to that conference.
HoPe this helPs
Jul 17, 2009 | AT&T Lucent MLS-12D Phone
Is there a Conference Call feature on ATT MLS 12D?
If by conference you mean inside and outside parties connected together the answer is yes. You should have a CONF button on the set. You press CONF, dial your second call and press CONF again. You can press CONF again and do it all over again to add a 4th party. There are restrictions and the conference is not amplified.
Here's a User guide to Partner phones. pdf page 3 has CONFERENCE instructions.
http://public.carl.airpost.net/Avaya/Partner%20Phone%20User%20Guide.pdf
Carl
Feb 27, 2009 | AT&T Lucent MLS-12D Phone
Time restriction on conference calls.
If this hasn't been solved, I am a certified Vodavi tech. Give me a call
Oct 29, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Uniden DECT 6.0 cordless phones
Here are some steps that should help. I don't think that you can Conference call You can hold a 3-way conversation (conference call) between your handset, an external caller and another internal handset user. During an external call: 1 Press . The external caller is put ?on-hold?. 2 Press or to select name, number or the handset you want to have a conference call with and press or key. The called handset will ring. 3 When the called handset answers, press to start your conference call. 4 Any handset can press at any time to leave the conference call. It looks like you can use the multiple system sets together, but the system is not designed to do what you are asking for. Please repost with any other comments or questions. Please rate this solution through fix-it. Thank you.
Jun 30, 2007 | Uniden DECT1080-2 Phone
Lands Phones Logo
292 people viewed this question
Top Tandberg Data Lands Phones Experts
Are you a Tandberg Data Lands Phone Expert? Answer questions, earn points and help others
