Question about Saeco Vienna De Luxe Espresso Machine
Alternatively slow brew and water under drip tray
I inherited this machine from my father and love it. Recently I have started getting alternatively either too fast or too slow brewing without ever changing the grind setting. It also seems like water and coffee "sludge" are leaking under the drip pan, particularly on the fast brews. I cleaned the brew group and spout but it didn't seem to help. Sounds like a clog somewhere behind the brew group but I don't know where to get started. Any help will be highly appreciated.
Thanks,
Camuyano
    New Friend:
    Problem Solver:
  • 5 Answers
Yes, as Pierre Laplante has said, behind the brew group there is a sort of triangular piece of plastic with a similar shaped hole in it. It has a small drain at the bottom that can be clogged very easily. The piece is glued fairly loose to the rest of the machine. I carefully removed the part to clean it thoroughly. Its function seems to be to funnel a little waste water into the wast water tray. Of course you can also clean it by not removing it. Once removed, you can glue it back on, or as I did, leave it unglued for easier cleaning once in a while. In that case make sure it stays in place when re-inserting the brew group.
Posted on Feb 13, 2016
  • 2,039 Answers
When you remove the brew groupyou see a plastic piece with 2 seal on it at the bottom of that there like a funnel with little hole hole get block with old coffee clean that so extra pressure come out thereif its block its should be full of water in there and for our slow brewing did you change coffee brand defferent expresso bean diff setting dont forget if you move the setting 1 move it only when our grinding coffee 2 when you move the setting dont forget to make a least 2 or 3 cup before moving the setting again let me no pierre
Posted on Jan 11, 2009
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
My Saeco Incanto Deluxe occasionally overflows with dregs and water under the machine prior to the "dreg drawer full" message being displayed. Is there a counter tray available for this machine?
Hi
Grounds and water under the machine or drip tray indicate that the drain behind the brew unit is plugged.
Remove the brew unit. You will see the injector in the back of the machine. Below the injector is a pocket that the excess pressure is relieved into when the machine is done making a coffee. This pocket will plug up with ground and oils. The drain is just above the center of the drip tray. Insert something into the drain and see if you can unplug it. Once it has drained run some hot soapy water through the pocket.
Apr 17, 2011 | Saeco Incanto Classic Espresso Machine
Hello my saeco vienna coffe machine leaks on the side when I make my coffee
Try changing the water inlet seal under the water tank (part # NM05.006)
May 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
The brew group does not seem to engage properly. All the lights work, along with steam and water out of the wand. The red light flashes and switches between red and cup back and forth. It does start the...
Hi
Check behind the drip tray for coffee grounds. Make sure that your drip tray is locked in. If its not fully locked it, this could be your problem. If everything is removed but the brew unit, grab the handle without pushing the press button, and pull. If the brew unit comes out, it wasn't locked in. Put the drip tray in. Set the brew unit on the drip tray. Now slide the brew unit towards the machine with a little force and see if that locked it in?
Jan 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Drip tray is filling up with water sooner than in
Hi
Either your grind is very coarse or your injector seal is bad. The injector is behind the brew unit and has 2 orange O-rings on it. See if you can wiggle the injector?
Dec 31, 2009 | Solis Master 5000 Espresso Machine
A puddle of water forms under the machine and
Hi
If its dirty water your drain in back is plugged. There is a pocket below the injector nozzle that the pressure is relieved in when the brewing is done. This pocket can get clogged with residue after a while and then overflows under the drip tray. The drain is in back just above the back of the drip tray. If you pour water in the pocket it should come out the drain. If it doesn't, clean out the pocket, and that should take care of it. If it does,t, I need more information.
Oct 30, 2009 | Saeco Vienna De Luxe Espresso Machine
1. After brewing a cup of coffee, when the grinds are emptying, a stream of coffee and grinds drains into the Drip Tray from the valve(?) in the rear right of the Drip Tray. We have gone into program mode...
HI
Excess water into the drip tray is an indication that you don't have enough coffee going into the brew unit. There is a lever on the top of the door that has a + on one side and a - to the front. Push the lever back to the full plus, then pull it forward 1 click. Try that.
Water into the drip tray is normal in small amounts. This is the release of pressure after brewing, like the 3 way valve on commercial machines
Sep 29, 2009 | Saeco Magic Comfort Plus Espresso Machine
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Significant leak into drip tray when brewing and using steam/hot water
run a 50/50 mixture of white vinegar and water thru your system.may have to run it twice,should clear it up if its a mineral clog. be sure to run a few cycles of clean water afterwards to clear the system
Dec 01, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
544 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
