Question about Dell Latitude CPX Notebook
My Dell latitude Cpx laptop just does not power up, just flickers
When i connect it to power, the lights just flickers but the screen does not show anything and with no minute.
  • bhcapell Jan 19, 2009
    I also have a CPx that will not power up. Pushing the power button illuminates the "on" LED and the hard drive LED. The three "lock" LEDs light (the leftmost one on briefly) and all these lights stay on for about 5 seconds, then all LEDs go dark. All of this is with the AC supply. I have pulled the battery and the floppy from their bays and get the same result. This unit worked when last turned on, and has been sitting for quite a while with the AC supply plugged in but the laptop was off. Any assistance would be appreciated.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 8 Answers
I had the same problem on my CPx. It turned out to be a bad memory module. With bad (or no) RAM, nothing is going anywhere, so it immediately shuts down. New memory, no problems.
Posted on May 19, 2009
Dell lattitude cpx charging pin and - TERMINALS
What? Is it time to wake up?
Oh yeah, Dell Latitude CPX,
http://www.amazon.com/Dell-Latitude-Notebook-650-MHz-Pentium/dp/B00005UJYF
AC adapter example for above,
http://www.prontocharger.com/ProductDetails.asp?ProductCode=d1161
DC Power Jack example,
http://www.all-power-jack.com/Dell/Dell-Latitude-CPx.html
I see the dilemma. The plug from the AC adapter has 3 socket holes, and the DC Power Jack has 3 prongs.
DC electricity has a Positive connection, and a Negative connection.
To find out which socket holes are for Positive, and Negative, let's look again at the DC Power Jack,
The Top view shows the jack upside down, and turned around. (In relation to how it mounts on the motherboard )
The bottom left view shows the jack primarily how it sits, (Mounted), on the motherboard.
The bottom right view shows the jack turned over, laying on it's front.
Also laying over to it's right side.
Note the three prongs. (Flat bladed pins )
The one in the middle is Positive.
The two outer prongs are Negative.
Looking at the bottom Left view, the Top prong is Positive, and the two bottom prongs are Negative.
Match it up to the plug on the AC adapter cable.
Going to test the Voltage coming out? (20 Volts)
The red Positive probe lead goes into the top socket hole, in the plug.
The black Negative lead goes in either bottom socket hole.
What if I'm wrong?
A Digital multimeter will just show a negative value. -20
An Analog multimeter's needle will go down towards the 0, instead of towards 20 Volts. (DC)
Just switch the probe leads around.
For additional questions, or if I am way off base, post back in a Comment.
Regards,
joecoolvette
Apr 29, 2012 | Dell Computers & Internet
I have a dell Latitude cpx that wont turn on.
may be you battary is corrupted....is it old battary?
Oct 27, 2009 | Dell Latitude CPX Notebook
Will a Dell CPX sreen fit as a replacement on a Dell Latitude PP01L
hello ! I don't think so coz there made different and diferent connections .
And if not carefull u will end up burning that screen
S i suggest that u get a new cpx screen and fix it
good luck dude
Sep 08, 2009 | Dell Latitude C640 Notebook
Latitude cpx screen went black and turned off
No i doubt she has done that matey.
try fiddling with the charger cable there might be a loose connection, fiddle with it until the charge light comes on then you will know what your problem is :)
hope this helps
Feb 16, 2009 | Dell Latitude CPX Notebook
Dell Latitude
If the system still works on an external monitor and functions normally otherwise, you might be able teo replace the LCD assy for about $150.
If the system no longer works on external either, then I'd say the system is no longer viable as an item to repair as it will be cheaper to replace it then to repair it. (New laptops start at around $500)
Feb 08, 2009 | Dell Latitude CPX Notebook
Dell Latitude cpx
Try to connect and external keyboard to it
with the external monitor.
If the shortcut is in the keypads where most off the beer propably came in contact.
will now be seen if its boots up.
If it boots up with external keyboard the ptoblem is in the beer soaked keyboard.
change or clean the keyboard with isoprophanol
to dissolve moisture and beer.
This is the solution. Please vote!!!
Jul 09, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
Dell latitude cpx will not power on
bad motherbord litte power tansformers on it getting to hot failed have to replace them or new bord
Jan 26, 2008 | Dell Latitude CpX Laptop PIII 500 Mhz...
Dell latitude CPx not start properly
CHECK THE POWER...THAT IS UR SMPS CHECK IT WORK PROPERLY
Jan 11, 2008 | Dell Latitude CPX-J Notebook
Dell Latitude CPX Notebook Logo
359 people viewed this question
Alun Cox
