Question about Lexmark T520 Laser Printer
My lexmark t520 wont print it says paper jam but there isn't one?
As far as I can see there is no paper jam. I read an answer about the sensor, but how can I fix this myself???
  • davidnh74 Jan 16, 2009
    I've got the same problem. Rollers aren't completely smooth. This problem happened after I used canned air to clean it out.
    Novelist:
  • 125 Answers
Hi Melissa:
I think that you problem is feed rollers. If you take the paper tray out and look inside you will see two white rubber paper feed rollers. If you feel them and they are smooth,then they need to be replaced. They should feel ruff.
Posted on Jan 09, 2009
You might need to really take a close look there might be a small piece of paper that is making the sensor read a paper jam. If the jam has been cleared but still reads jammed you might want to shut the printer off and completely unplug it for about 5 minutes. Plug it back in and see if that helped...
Posted on Apr 04, 2009
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
My T520 Lexmark prints a first page that reads @PJL SET LIMAGEENHANCE = OFF, why? and how do I stop it?
I had the same problem and I fixed it this way. I uninstalled the printer driver then I went to the Lexmark site and under 'Drivers" I typed in t520 driver xp. There are a couple of them, pick the mpmoinxe.exe one it comes with an install. When you get to the choice of a t520 or a t520sbe pick the t520. The install will guide you through. When I got done the problem disapeared. I hope it works for you too.
Jan 04, 2010 | Lexmark T520 Laser Printer
Lexmark t520 suddenly prints poor quality, i.e. the previous page prints softly onto the next page and the right side of the page (2" from right) is streaked with toner. Please help. TIA, Mike
this sounds like you have a fuser problem look at the fuser and see if it has toner build up on the rollers ghost printing can be caused by the toner cartridge or the fuser. this would indicate that your fuser isnt maintaining enough heat for complete fusing. is you take the rear covers off and run your print job. look to the far left side of the fuser and you will see the heat lamp lit up. this light should cycle on every 1 1/2 pages or so. any longer than that and it wont keep up with the print job
Oct 28, 2009 | Lexmark T520 Laser Printer
The screen reads remove paper standard bin. We
if your getting a standard bin error this is caused by the flag on the top of the printer where the paper comes out or the sensor that it triggers. look to the far left where the paper comes out you'll see the flag make sure it moves freely if it does replace the sensor
Sep 15, 2009 | Lexmark T520 Laser Printer
Paper jammed part way
try to unplug your printer and restart your computer..
May 13, 2009 | Lexmark X3550 All-In-One Printer
Re: Paper Jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Lexmark X3650 Printer
Paper jam
Sensor on the Left hand side, as paper feeds into the guide from the cassette . sensor gets kocked out of position.
Nov 06, 2008 | Lexmark T520 Laser Printer
T520 Printer - slew of issues.
Replace the fuser. These are the same as a Dell 5200 printer, and a fairly common problem.
Jul 23, 2008 | Lexmark T520 Laser Printer
Re: Paper Jam
most likely something jammed down deep, or the rollers need cleaning..
Mar 28, 2008 | Lexmark T520 Laser Printer
Lexmark x1180
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 13, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark T520 Laser Printer Logo
612 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
