Question about Troy-Bilt 25cc 2-Cycle Backpack Blower with Harness Padded Design #41AR2BPG966
Rebuilding a 25cc Craftsman 2 stroke engine
I had to restring the starter rope just trying to verify the correct direction of the plastic fan to ensure I have it back together correctly does the fan suppose to turn counter clockwise as that is how it is working now- seems like the blade should be going clockwise to create the most air. Thanks for your help! Bill
2 Suggested Answers
  • 28 Answers
SOURCE: troy bilt string trimmer starter rope
you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
Posted on Aug 06, 2009
How to restring a Honda gx25 weedeater 4 stroke
Honda UMK425U 25cc 4-Stroke Brushcutter String Trimmer ...
? 2:02
www.youtube.com/watch?v=EicRxA3nE-Q
Mar 6, 2014 - Uploaded by alexaescht Honda UMK425U 25cc 4-Stroke Brushcutter String TrimmerLine Trimmer Startup Cold Start Revving Sound ..... I totaly agree love my gx25.
Sep 20, 2015 | Honda Motorcycles
Poulan pro bvm200vs switch wire harness
They generally ground through one of the screws that hold the cover(s) on to the engine itself.
Aug 09, 2012 | Poulan Pro Bvm200vs 25cc 2-stroke Gas...
Pull starter rope craftsman 358-791050
there should be 4 bolts holding the pull rope and spring to the motor if you need more info. go to Sears Parts.;co.com
Aug 20, 2017 | Craftsman 25cc Gas Line Trimmer
Fuel mix for 25cc trimmer
For two stroke engines of this capacity the ratio of fuel to two stroke oil is (25:1) 25 fuel to 1 (two stroke) oil. Eg 200 ml of two stroke oil to 5 litres of fuel.
Jan 27, 2012 | Craftsman 25cc Gas Line Trimmer
Pull rope will not pull out when trying to start
Disassembly will be required to get to the cause of this problem. This problem alongwith the rope being pulled out and not drawing back in are among the major consumer complaints.
Some may think the worst in this situation, that the engine has gone bad and "locked" up. Most of the time though, the problem is misalignment of all parts on the main shaft or the recoil unit itself. It is plastic and the shaft is steel and wear occurs. This can be fixed however but there is some teardown work involved and it does require mechanical abilities to do it.If you are somewhat inclined, start taking the machine apart (starting with the tube that holds the flex shaft that turns the string head). That would be your starting point, directly in front of the engine/coil/starter/flywheel assembly. You will need to remove the throttle cable from the carb and disconnnect the kill switch wire from the ignition coil. From there it is on to taking the front engine cover off (covers the clutch housing/clutch/starter recoil/flywheel/coil. So you see, there is quite a bit of disassembly involved to get to the starter recoil unit
Aug 28, 2010 | Craftsman 25cc Gas Line Trimmer
Trying to remove a clutch rotor assembly on a craftsman trimmer and not sure how to remove it. looks like it unscrews from the shaft
It does unscrew from the shaft. The Torx screw holding it is hidden and doesn't come out of the housing once it is loosened. It is screwed into the end of the shaft. You will have to keep the engine from turning to loosen it. Pull spark plug out and move piston to bottom of stroke. Put some nice, soft, clean rope in the cylinder and let the piston compress it when you turn the Torx screw in the clutch rotor housing.
Jun 30, 2010 | Craftsman 25cc Gas Line Trimmer
Rope to start want recoil
The starter pawls on this model are exposes to weather. You can usually spray WD-40 directly to the flywheel pawls and loosen with a screwdriver.
Apr 30, 2010 | Craftsman 25cc Gas Line Trimmer
Broken pull starter rope
remove pulley that rope goes on, wind it with new rope, wrap it till it is full, then feed rope thru hole in housing, put pulley back in place, put rope thru pull handle, pull thru till you feel spring catch tie a knot and that should do it......be careful when removing pulley not to dislodge recoil spring
Oct 22, 2009 | Garden
What are the factory settings for the l & h needle valves on the 25cc carb?
usually 1 1/2 turns from snug in will be right. this is true on most all 2 stroke engines and 4 stroke that use a diapraham type carb
Jul 07, 2009 | Craftsman 25cc Gas Line Trimmer
Troy-Bilt 25cc 2-Cycle Backpack Blower with Harness Padded Design #41AR2BPG966 Logo
624 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
