Question about Zenith XBV342 DVD Player/VCR
No clock display
Hi I recently moved house and had to reset up my DVD/VCR. The clock is now not showing on the display. How do I fix this manually? Thanks.
    Genius:
  • 1,074 Answers
Plug out the DVD/VCR and let it stand for about 2days and see what it does.if that does not work,then call a tech to look at it.good luck.
Posted on Jun 04, 2007
Alba DVCR-2 Err:03, Err:02, Err: 01 problems
you have a faulty SYSCON MICROCONTROLLER.+faulty associates circuits, like CLKS, RESET.
you must go to the repair shop TV for fix it.
However you can try as the last thing before to go the repair shopt, Clean tHE VHS+DVD, with tape cleaner+disc cleaner too.and Proof
God bless you.
Aug 02, 2012 | Broksonic DVCR-810 DVD Player/VCR
How do you set the clock
Hello
To set the clock to your SV-dvd 3E:
Your DVD-VCR contains a 24-hour clock and calendar used to:
Automatically stop programme recording
Preset your DVD-VCR to record a programme
automatically
You must set the date and time when:
You purchase the DVD-VCR
Do not forget to reset the time when you change
clocks from winter to summer time and vice versa
[1] Press SETUP on the remote control.
Result: The MAIN MENU is displayed
[2] Press the corresponding up/down button or Forward/Reverse buttons to select the
CLOCK SET option.
[3] Press the ENTER button to select this option.
Result: The CLOCK SET menu is displayed
[4] Press Reverse or Forward button to select the hour, minutes, day, month and year.
Result: The option selected flashes
[5] Press the Up/Down buttons to increase or decrease the value.
Result: The day of the week is displayed automatically
You can hold the Up/Down buttons down to scroll more
quickly through the values
[6] On completion, press RETURN twice to exit the menu
OK.
Oct 10, 2011 | Samsung SV-DVD3E DVD Player/VCR
Set clock on sd-kv550-su
There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
Hope this helps,
James
Auto Clock Adjustment
Preparation:
• Turn ON the TV and select the corresponding video input.
• Press VCR DVD selector to select the VCR mode.
(The VCR mode indicator will light.)
1. Connect the Antenna or Cable system.
If you use a cable box, turn it on.
2. Plug the AC power cord to the AC outlet.
3. Make sure the DVD/VCR is turned off.
If you press POWER, the Auto Clock set is not programmed.
4. Wait at least three minutes and press POWER.
5. Press CALL DISPLAY to check the clock setting on the on screen display.
6. If the clock is not set, check the antenna
condition. The AUTO CLOCK may not function properly if the reception condition
is not good.
Manual clock setting
1. Press VCR MENU.
2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
3. Press SET + or – to select “CLOCK SET”, then press ENTER.
4. Press SET + or – to set the month, then press ENTER.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically
Apr 25, 2010 | Toshiba SD-V295
Have SANYO VCR/DVD Model E175216 and can't locate timer button for late night programming
Hi, if ithere is no button on the front of the unit or on the remote, then simply setting the unit to standby with either power button should make the unit enter the timer record mode. (This will be indicated with TIMER or a small red clock symbol in the display providing all the conditions have ben met. i..e clock & timer correctly set, tape in machine, etc)
Mar 16, 2010 | Sanyo DVW-5000 DVD Player/VCR
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
VCR, DVD PLAYER
Try resetting the unit. Push and hold the on/off button for 10+ seconds. --or-- Look for a reset button behind the drop down door, and gently depress it with a pen point for a couple of seconds. If this does not work, try calling Panasonic.
Apr 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to set time and date
Turn on. Goto channel 3 or 4. Press DVD/VCR button until display says VCR. Press TV/VCR button until the display says VCR. Press SETUP button. Select SYSTEM SETUP. Select CLOCK SET. Edit time and date. Press SETUP button.
Jan 07, 2008 | Toshiba SD-V394 DVD Player/VCR
Phillips TV/VCR combi 14PV400/07
To solve this problem, cancel the wake up alarm !
Dec 23, 2007 | Philips 14PV225 14 in. TV/VCR Combo
Problem with DVD-VCR combo
I found if you disconnect the power and keep it off for thirty seconds or so to let it reboot, the "SAFE" problem disappears.
Sep 04, 2007 | GoVideo Go Video DVD/VCR Combo
Zenith XBV342 DVD Player/VCR Logo
145 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
