Question about Intel D945GPM 945G Ewith Windows XPress Socket 775 mATX Motherboard with Video Sound LAN
Cpu fan noise problem
I installed a 1GB ram (hynix ddr FSB400) on my intel d915gag MB after reboot my cpu fan rotates at fastily and in the process makes a lot of noise i want to reduce the noise as was previously Actually certain fans speed up with increase in CPU Processing n create noise n not due to dust.......Mine is one of these.... i dunno abt the fan but my Processor is a P4 3.4G on an Intel 945 motherboard Any word on tht??? :S
  • 535 Answers
You should check and make sure the inside of your computer isn't dusty. Dust will wreak havok on fans and shorten their life. Plus it likes to build up between the fan and heatsink which will overheat your processor. Take the fan off and spin it with your fingers. I like to open the little sticker on the bottom and put some 3 in 1 oil to lubricate it. A smooth spinning fan is a happy computer. It also reduces noise that a dirty fan makes. Hope this helps you.
Posted on Jan 09, 2009
My desktop has intel 845gvsr board, n have a 256 mb ram installed on it. i want to upgrade it to 1gb what kind of ram should i go for
Each memory slot can hold DDR PC2700 or DDR PC3200 Non-ECC, Non-buffered RAM with a maximum of 1GB per slot.
You can refer to this site for more info on your RAM and motherboard.
http://www.crucial.com/store/listparts.aspx?model=D845GVSR
Thanks for using Fixya.
Feb 23, 2010 | Intel D845GVSR Motherboard
What is the hidhest ram i can use on a celeron 2.6
Hi. The amount of memory that can be installed is limited by the motherboard, not the CPU. That being said, the motherboard you have listed will take the following memory:
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.
Sep 28, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
Pc keeps rebooting
Try re-installing the operating system. It is possible it possible OS is not installed properly. (ehteshamhusain@gmail.com)
Jul 19, 2009 | Computers & Internet
I have upgraded my k7s8xe with athlon xp 3200 cpu. I have adjusted the jumpers to fsb 200 & installed 1gb ddr 400 ram. system keeps rebooting os vista enterprise. any suggestions. also can i install 2...
First of all, if your FSB is set to 200mhz, the system will not support DDR400. "CPU at FSB 200MHz mode, it will NOT support DDR400". The FSB will have to be either 333 or 400mhz in order to utilize DDR400. Only 1GB of DDR400 is supported. As to your rebooting issue, could be because of these incompatibilities and/or you did not properly seat the heatsink/fan on the new CPU, which also means you might not have properly applied thermal compound or might have no applied it at all. All the compatibility information for this motherboard can be found at: http://www.asrock.com/mb/overview.asp?Model=K7S8XE
It appears that the 1GB RAM that you installed is generating more heat due to the density of the chips they require more power. This is what is causing the fan to work harder. To verify this you can re-install the original memory and see if the fan noise reduces due to lower heat.
Aug 08, 2008 | HP Pavilion dv6000z Notebook
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
Windows xp
hi
is this your motherboard? http://shop.pcmag.com/shop/product_specs/Intel+D915GAG+BLKD915GAGL10+Motherboard/22673983.aspx
if so, it is ok for you to upgrade your memory up to 2gb. btw, just be sure to properly install the rams to the slots.
since youve purchased 2 x 1Gb ddr400 , put on color blue slots.
hope this helps
Jan 23, 2008 | Intel D915GAG Motherboard
Sep 16, 2007 | Intel D915GAG Socket 775 Motherboard -...
Intel D945GPM 945G Ewith Windows XPress Socket 775 mATX Motherboard with Video Sound LAN Logo
126 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
