Question about Epson Stylus DX5050 All-In-One InkJet Printer
Compatable inks can i get my epson DX5050 printer to accept compatible cartridges
    President:
  • 1,179 Answers
The easy answer is yes, but Epson's are notorious for clogging up when you are not using epson genuine ink. Everytime I have used anything but an epson cartridge im my printer it has cost me more to clean it then if I spent the extra $ on epson ink. Hope this helps.
Posted on Jan 09, 2009
Epson Stylus TX400. Refuses to accept either compatable or refilled cartridges?
Epson TX400 is so sensitive in terms of ink cartridges, you can only replace a refilled ink cartridge in this type of printer if the cartridge has an automatic ink reseter chip. When you replace a cartridge in your printer, it will automatically register the ink level in the chip. So you need an ink reseter chip to replace a new refilled cartridge.
Feb 17, 2011 | Epson Stylus TX400 Series
My r265 wont accept compatable ink cartridges is there a setting to change this so i can use them?
mcdevito75 here, Best Bet type in Epson inkjet printer in search and ask the computer if these compatable cartridges can be used and how.
Jun 23, 2010 | Epson Stylus R265 InkJet Photo Printer
How to print using black ink only on Espon dx5050?
Did you use Epson Genuine Cartridges??
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
If you have Genuine Epson Cartridges, and have ink in ALL THE CARTRIDGES, to print in black only, Make the following settings on the control panel. SEE BELOW:
Select the number of copies.
Select l [Plain Paper].
Select the paper size you loaded.
To make a color copy, press the
x StartE[Color] button.
To make a black-and-white copy,
press the x Start D [B&W] button.
If you find this information helpful, pls rate me.
You can download the entire manual. Just click on link below. I found on the web:
http://safemanuals.com/314159.php?k=3c8871ac74c76c7b6bdba73063efb872&ID=552849&q=EPSON%20STYLUS%20DX5050
Thanks and Good Luck
and pls rate me.
Feb 16, 2010 | Epson Stylus DX5050 All-In-One InkJet...
Epson SX200 refuses to recognise compatible cartridges
Hi Howard,
Bottom line, if the printer doesn't accept them, then they are not compatible... I'd recommend returning them for a refund and find a supplier that has tried and tested cartridges.
I'd love to be able to recommend a supplier but as I don't have an SX200 I can't... Others might be able to help if you can indicate where you are in the world as the SX200 is, I believe, zone specific.
Best of luck
May 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Epson R260 won't use new Epson hi-cap lt cyan cartridge
Please log on to epson.com and get the ink pad reset utility software from there. It runs on win xp and win vista.
Apr 10, 2009 | Epson Stylus Photo R260 InkJet Printer
Epson DX7400 not accepting non standard inks
It's entirely possible that you've been sold CX7400 cartridges and not DX compatible versions.
I would see if you can source some cartridges from somewhere in the UK that are compatible and see if that solves the problem...
It's also possible that the cartridge chips are soiled, broken or similar so I'd take them back to the store and get a refund.
Hope that helps.
Mar 05, 2009 | Epson Stylus C86 InkJet Printer
My sx200 wont accept compatable ink cartridges
If you are using refilled ink with epson it can cause the print head to go bad. Epson is very picking when it comes to their ink. I would suggest using there ink
Feb 12, 2009 | Epson Stylus Multifunction Inkjet Printer/...
My epson r285 wont recognise compatable inks
My Epson R285 will not recognise compatible cartridges,mainly the black.I ran out of black ink and installed a compatible cartridge but it did not recognise it.To get the printer running I had to buy a genuine one which worked.I then ran out of all the other colours soon after and installed compatible ones which were accepted.I have now ran out of the black again but the printer will not accept the compatible cartridge.How can I solve this problem as the printer has accepted black compatibles before.
Thanks Padgy
Oct 09, 2008 | Office Equipment & Supplies
Installed compatable cartridge for epson dx 7450 printer rejecting non epsom cartridges
I have an Epson dx 7450 scanner printer that will not accept non epson so called compatibles .Anyone found a solution ? I've tried a number of manufactuers and they all don't work . I really don't want to fork out for epson inks ?
Sep 30, 2008 | Office Equipment & Supplies
Epsom R200 COPY INK DOESNT WORK
There is no solution, I have tried this myself, there are compatible inks for this product, you just got the wrong ones, However it may only be down to one of the inks, check the ink levels before removing, if all empty, then they are not compatible.
swampduck
Jan 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus DX5050 All-In-One InkJet Printer Logo
225 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
