Question about Tommy Bahama Island Palm 2 Tone Link Watch TB3023
How to shorten a wrist banc for a TB4008 watch
How do I remove the pins or shorten the band?
  • 2,334 Answers
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 09, 2009
Wrist watch shortening
Look at the inside of the band and there will arrows pointing what direction the to tap the pins out to remove links. Put the watch on a small roll of tape or something similar that keeps the band off the surface you are working on. Gently tap the pin out with a tool that will fit in the pin hole. Remove the pin and determine the number of links to remove. Remove the links and reverse the order in which you took it apart .
Apr 27, 2014 | Citizen Eco-Drive BL006056H Wrist Watch
How do I shorten ******** my Tag Heuer Formula 1 watch?
Take a look at the watch from the side where the band attaches to the buckle. You should see four holes with one of them having a visible pin in it where the band is connected to the buckle. Moving the band to the right will shorten it moving it to the left will make it bigger. To move it simply get something that you can push the pin in with like a paper clip. Push the pin in and the band should come out move it to the left and push the in again and simply move the band into proper position. Once you do that the pin will snap back into place. If that does not adjust it enough go to your local watch store and they can remove links from the bracelet for you. Shouldn't cost you more than $10.
Dec 14, 2013 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Shorten wrist band on a RADO CERAMICA JUBILE mens watch
mcdevito75 here, Rado a great watch and with a $50.00 band, at least. BEST BET, look for a small watch repair shop in your area for this band adjustment. Links are held in by special pins and a link remover tool is need to remove these links.
Feb 11, 2011 | Watches
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
How do i shorten a metal watch band i have a casio 708
Look for removable pins in the band to allow removing one link at a time until it fits ok.
Dec 06, 2009 | Invicta Pro Diver 9321 Wrist Watch
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
Skagen 596XLTXM Titanium Mens Watch
good morning ! you need a puncher pin and anvil to remove the pin on your watch band punch or push the pin use the puncher pin according to the arrow sign,full the pin to remove,and fush to fix again,do it carefully,thank you ! god bless .
Aug 27, 2008 | Skagen 355LGSC Wrist Watch
If it not obvious how the hinge pins are removed, then I suggest that you go to a watch shop to do it for you.
Apr 15, 2008 | Fossil CH2332 Wrist Watch
Shortening the Length of a Metal Wrist Band
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
Nov 06, 2007 | Kenneth Cole KC3289 Wrist Watch
Shorten watchband
I have a similar watch and removing the links are not easy. There are pins in certain links that have arrows on the inside of the band. I used a push pin to remove the pins in the direction of the arrows. Snip the end of the push pin with a wire cutter or pliers so that it fits into the hole and tap the top of the push pin with a small hammer until the other end of the pin is exposed enough to extract it with a set of needle nosed pliers. Repeat for other side of link. When the pin is extracted, twist the link inward and it should snap out.
Remove the link and reverse the procedure, placing the pin in the opposite direction as it was extracted. You may have to tap it gently with the push pin and hammer to get it to go into the holes flush.
It takes a little while and some patience, but if you can get someone to hold the band for you while you tap the pin, it will be easier. Also, if you remove the spring loaded pin from the band fastener so the band can be laid out straight, it will also be easier. Good luck!
Mar 30, 2007 | Timex Outdoor Casual Expedition®...
Tommy Bahama Island Palm 2 Tone Link Watch TB3023 Logo
315 people viewed this question
Top Tommy Bahama Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Tommy Bahama Watch Expert? Answer questions, earn points and help others
