Installing 4 new AA batteries in the camera, I stupidly installed the last battery with the wring polarity. I quickly corrected the polarity of the AA batteries, buy now the camera will not power up. Please advise. Thanks
SOURCE: Nikon F100 dead
I do know that on earlier models like the N90s and 8008s, the small nut that holds the battery clip in place activated a cut off switch. If the switch was faulty, the camera would not turn on. There may be a similar switch in the F100.
SOURCE: my nikon n55 is flashing err after installing new film
It could be that your camera doesn't know it's rewound the film already. With the camera turned on, push and hold BOTH manual rewind buttons simultaneously - one near the release button ( +/- ) and the other toward the front of the camera at the lens release button. Try the release button again.
SOURCE: batteries go dead fast
Hello
Thank you for using FixYa for your problem
No there is a short in the system somewhere, as you have just had it repaired you should have a guarantee for this repair.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Testimonial: "Thanks Richard, I will send it back to them to fix. Have a great Christmas holiday@"
SOURCE: Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
