Question about AutoCommand Remote Start and Security with Keyless Entry
Remote start is intermittent working
Auto command remote start is not working properly on a 2005 dodge stratus. Unlock,lock and trunk pop work normally. Sometimes the car will die a minute or 2 after it is remotely started. Can anyone help?
  • 1 more comment
  • shuffmopar Jan 09, 2009
    would this cause it to intermitently work though...sometimes it does start remotely, but not always...it seems like the remote batteries are weak or something. How come it works sometimes and sometimes it doesn't? wouldn't the remote start not work at all?
    Thanks,
    Steve
  • markeedee311 Mar 27, 2009
    My girlfriend had an Astro Start RS-613 remote starter installed about a month and a half ago, and complains of intermittent no-start conditions, from various angles of approach and distances, and also from within her office building. Sometimes it works under all of these circumstances, sometimes not. It has a 1,500 ft range, and hardly ever, is she even half (or even a third) of that distance away from the vehicle. Any thoughts, ideas? What can cause interference in signal strength?
  • andiamo924 May 22, 2009
    have 2007 lexus es 24,000 miles. been having intermittent starting problems with keyless ignition. had it towed to Lexus when no one could get it started in my garage. they replaced start push button. next day same thing. ready to bring it back, then can't get it started.
    finally got it started, drove it to lexus and now they say it's because i had 2 fobs in the car. told my advisor that i put them in the car on the way down in case the fobs were the problem. this has happened at grocery store, dept stores etc. usually will start. batteries in fobs and lojack fobs have been changed. now i will pick up the car tomorrow and i know i'll be back. at first i used to think i was pushing start before stepping on the brake. NOT. service advisor says they've never seen this problem and they even had a lexus field tech there trying to figure it out. this is my 2nd lexus and the one with 100,000 miles on it never had a problem, that's why we bought another one. yes, when lexus tried to move it into a service bay it wouldn't start, but they think it's because 2 fobs in car. one fob does the same thing. i know when i pick it up tomorrow, i'm telling them, that i'll see them soon again.
  • 34 Answers
The problem is your car is equiped with a passlock system you need a by pass mod. part number 555-L this is a dei part number this is the only company i use. it is a simple three wire hook up. if you got this far you will not have any trouble. one other thing to check is your ignition wirers make sure they have power when they are suposed to.if your still having problems or need more info on getting part let me know. i have alot of exp. with auto starts and keyless entry.
Posted on Jan 09, 2009
2006 Dodge Stratus, driver side door lock actuator not getting power. Replaced actuator didn't work. Need location of the relay wiring to try that next?
Nick:
I would not go and fix the relays: those are inside the BCM or "Body Control Module" located under the dashboard to the extreme left or driver's side. Believe me, it is a nightmare to remove from the car and very expensive to repair at specialist shops.
In my 2002 Stratus Sedan R/T Turbo (Mexico), the door locks started to ignore the door switches or the remote at about two years from new, but as it was an intermittent failure, I didn't go to the dealer to fix it under warranty. But after two more years and just out of warranty, the failure was more frequent. After six years of use, all the doors were ignoring the commands from either the door mounted switches or the remote.
The thing is, "modern" cars are designed with too much reliance on software and computerized modules to perform simple tasks previoulsly done with simple wiring and relays. This is the case with the door lock actuated by a BCM. In the older Spirit, LeBaron, Reliant etc. generation designs, you had three wires to the small motor actuating the door lock mechanism. But some "too-intelligent" so called automotive designers decided a "better idea": to multiplex the lock/unlock commands on only two wires, "saving" a few feet of copper wires, but requiring the use of a complex Module, that ends up being much more costlier, heavier and unreliable! (but in that way the too-intelligent software (ab)using designers were happy).
I solved my problem by disconnecting the door locks wiring to the BCM and paid a much lower price to a technician that installs cheap car alarms that have their own remote control. In that way i saved about $350 USD... you decide what to do! Best Luck, Amclaussen.
Apr 05, 2014 | 2006 Dodge Stratus
On my 2004 dodge stratus the door lock switch on the drivers side does not unlock the doors. It will lock all of the doors and the windows but it just will not unlock. The passenger side still works for...
I have answered this subject many times: it is a bad BCM or Body Control Module. The problem begins intermittently, but progresses during two to three years and finally inutilizes all door locks. As BCM repair and removal from the dash is a real pain, I resorted to disconnect the wiring to the BCM and paid a much lower price to a Car Alarm installer to put an inexpensive alarm that comes with its own remote. In that way I use the new remote to lock-unlock and the original one to set the original alarm-inmobilizer. Amclaussen.
Aug 02, 2013 | 2004 Dodge Stratus
My remote will not unlock or lock my doors
The fuse box is in the trunk you can't get it too. Cleaver design there if I do say so myself. However my guess is that your key has failed, and you need to get a new one. I have seen on the older keys the contacts inside the fob letting go. They can be soddered back together. I have not had this happen however on 08 models and newer.
Oct 04, 2012 | 2008 Dodge Charger
I left my trunk door open all night and my battery died. I thought the key I use for the ignition would be the same key to unlock the door if the battery died? How do I enter my 2006 Dodge stratus with the...
Thank you for contacting fixya.com.
The key lock/unlock for doors are powered by the batteries in the remote, while the ignition key draws its energy from the vehicle via induction. Since the battery is dead you are having this problem. You need to call assistance from the nearby auto shop or a locksmith. I guess you don't have any other option.
Jun 27, 2011 | 2006 Dodge Stratus
I have 2 remote starters for my 2005 Chevy malibu. the remote start does not work on either of them, but the other features ( unlock and lock doors, open trunk and alarm ) all work fine. what can i do to...
IS THERE A CHECK ENGINE LIGHT ON? if so this disables remote start. and is remote start turned on in the options menu? does it do anything? lights blink
Dec 21, 2010 | 2005 Chevrolet Malibu
Remote start doesn't always work
It is that way because you wouldnt want the car starting when you have it it in your pocket or purse.
Sounds like the keypad contacts may need cleaning, or have been bent/broken/etc.
Have you tried another (backup) keyfob?
Please do this and report back.
If you are having problems, the installer should troubleshoot for you for free.
Jan 14, 2009 | AutoCommand Remote Car Starter Add-On
Key doesn't work to unlock door locks & remote doesn't work fully
try getting some dry lubricant and applying it in the lock this usually works well. cold weather usually makes the problem worse.
Jan 05, 2009 | 2000 Nissan Altima
AutoCommand Remote Start and Security with Keyless Entry Logo
906 people viewed this question
Top Design Tech Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Design Tech Vehicle Part and Accessory Expert? Answer questions, earn points and help others
